Hi to all,
It has been a long time since I did not give any news, sorry.
In fact, I could not take care of my XS because my friend has had strong personal problems.
I went to the garage last Saturday, to work on a new problem that suddenly appeared on my beautiful C or D XS.
After a complete rebuilding and the indication given, that the throttle cable should be on the frame and not out of the tank
, I took off the tank to put the cable along the frame, and... the video talks by itself.
I must say that air boxes are out (the problem occured, even with the boxes on the machine, that the idle is correctly set according to Haynes, and that nothing else has been changed).
The choke is activated to help starting ; if it's off, the XS won't start.
What more could I say...
I opened the caps over the carbs and the diaphragms are ok, i.e. not dry at all.
When I put the finger into the carb outlet, I can push up listening the "psssssch" sound, and the assembly is going down by itself.
I guess the problem can be the air mixture, but the screws has not been touched... The plastic cap on the screw is missing, but I can't imagine it matters.
Of course, do not listen to the comments in the vid, except if you want to improve your French
Thanks for your help ; I am availabe to answer any question to help to find the solution.
