My '83 is my 'go to' bike for daily riding. It's done and needs no more, mechanically speaking. The '77 was done mechanically too but became a parts tester when I acquired the beaten and abused '78, and in the process of getting the '78 road worthy the '77 wound up with the '78's carbs.
I had to disassemble and clean those carbs out as the mud daubers had found a nice home there. Once cleaned, reassembled and mounted they ran but not great. The bike would start fine and accelerate but as she warmed up she would hang with a slow return to idle. So today I figured I'd get into them again and try to figure this out. First thing I did before pulling them off was to check the diaphragms. Left carb first, raise the slide, cover the top crescent hole, release slide.......excellent, slow drop. OK, right carb. Lift the slide......wtf? This don't feel right.
It seems that Fredintoons Mr. Bodger character was into this carb and put the slide in backwards.....looks like he visits here too from time to time........ lol
Alright, took the top of the carbs cover off in situ and turned the slide, bevel side now facing towards the air filter. Buttoned her up and road tested. Could it be this easy? Yep. Bike runs sooo much better, and the sound of the stock headers with the Commandos is almost heavenly.
Next up is to count the teeth in that rear sprocket. I'm thinking it's a 32 I've put in there and if it is I'm going back to a 34, fun factor.
