I was wondering if any of you all experienced this and if it means I should investigate further by removing the head:
Engine runs well, no leaks evident on several test runs of 10-30 minutes each over 2-3 months (restoration job so I got the engine running and have now stripped it down).
2 days ago I removed the engine by gripping it by the kick starter, putting my fingers in the left exhaust port, and lifting it out with a grunt or 2. Placed it carefully on a dolly where it sits now.
Just checked it over and there is oil seepage on the left side under the exhaust port. So did my engine removal method in effect separate the gasket seal between the head and jugs on the left side, or maybe the oil was just sloshing around and it is a one-time thing?
The oil seepage seems to have been limited in quantity, but I probably won't know if there's a permanent problem until I get it back on the frame and running again.
