1. Dismiss Notice
    Dismiss Notice
Header pipe to head fitment
Discussion in 'The Garage' started by The Tin Man, May 23, 2020.
  1. The Tin Man
    The Tin Man XS650 Addict
    Hi all!
    I have a set of header pipes I'm looking at using. The end of the pipe that seats into the head seems worn or uneven to the face of the welded flange. It varies from 5/8 to 1/4. I'm wondering if it I need to square it up by refacing it or even build it up with a weld and reface or if it's just fine? Your advice appreciated.
  2. Ratranger
    Ratranger XS650 Junkie Top Contributor
    I don't think that part make a big difference. The rings are what holf it all in place and crush the gasket.
  3. The Tin Man
    cool learning all the time.
    lakeview likes this.
  4. 5twins
    19,240
    10,460
    813
    Yes, that end just sticks into a step cut into the exhaust port and centers the pipe. It doesn't butt up against anything and seal. Here's a cutaway view of the MikesXS torque insert. It's designed in a similar manner to the end of a stock headpipe. As you can see, that stepped down end doesn't seal to anything, just centers the part in the head .....
    [​IMG]
    The Tin Man likes this.
  5. The Tin Man
    Thats why you are a Guru,, how goods the cut away!. i am member of the AND the National Dyslexic Association a picture is worth 1000 words!
  6. The Tin Man
    Does anyone use3 muffler putty or gue of somekind or just the gasket? Im wondering the same at the moffler header join. seems it could be a little leaky?
Share This Page
