Hello, I just finished putting together my 78' xs650se and when I turn it on the headlight will not run and all of my signals and rear light are now dimmed. Any ideas on what could be causing this? and a simple solution to fix? Thanks
Have you eliminated your RLU (Reserve Lighting Unit)? If not, I would do so. They can cause all sorts of weird electrical problems if they go bad. Follow the simple instructions here .....
http://www.excess650.co.uk/tips & tricks.htm
OK, I just came in from farting around in the shed , fired up my bike with the new UNIs on ( noticeable difference ,smoother idle and had to turn the idle down ) . I decided to remove the reserve lighting unit , everything seems to work fine without it , but I see the link in the post by 5twins says to connect the blue/black to the blue /yellow , so should I cut that plug off and connect them or just run a wire from one to the other and leave the plug on ? ( just incase for some reason I need it later )
I always leave the stock connectors/plugs as they are. You never know when you may want to go back to the way it was. I suggest you make up a wire with the compatible connectors, to jumper the 2 wires togther. No need to do anything with the other wires.
I know most folks remove the RLU, but I still have mine on my bike. It just sits there and causes no problems, so I just leave it alone.
