I'm going to have to post the exercise routine at another time. My computer hick-upped and i lost half of what I wrote...
Gary made me realize that, although we have similarities, we are all different. Some of us have active, physical lifestyles, dictated by our environment, while others may have physical issues which limit their ability to do so. Once again, I appreciate the input especially as I don't want to give anyone bad advice. Being on either end of this spectrum could cause cause someone not to benefit from this routine and could cause it to be detrimental. There are tailored exercise routines all over the web. You should consult your doctor if you haven't picked up a bar bell in years. My brother was working out, one day and my Dad approached him to ask if he could try to press 65 lbs. He did it, but then had a heart attack. My dad probably hadn't lifted weights in over 30 years. He was 56. That is not a good weight to start with. And, if it's mud season with a foggy drizzle on a foot and a half of mushy snow, a little exercise may help you get through it. It's better to exercise with someone. I exercise with my wife and we encourage each other to do so. It's best that the amount of weight and reps are decided by you.
Exercise Routine:
1) Push -ups
2) Roman Crosses (lye on your back, cross your arms on chest, grabb opposite shoulders and bend knees, feet flat on floor and come up off the floor with your upper body 1-2"
3) Leg Lifts (lye on your back, place hands under your back next to your spine to take pressure off spine, when you raise your legs up over your head.
4) Scissors (lye on left side and raise and lower right leg, and after doing a set, turn on opposite side and repeat
Weight Routine
Dumb Bells (water jugs can be substituted)
1) Lying Fly (on your back, arms straight out to side bring weights together over your chest)
2) Flys (standing, weights down at your sides, raise arms to 45 degrees) (any higher may put too much strain on shoulders)
3) Tricept Kickback (lean forward, arms down, raise arms to rear as if you are diving into a pool)
4) Upright Row (standing, arms down at your side, raise them as though you are picking up suitcases)
5) Reverse Fly (bring arms over your head and bend your elbows, then raise weights straight up over your head)
Bar Bell
1) Reverse Curl (palms down, bend elbows)
2) Chest Press (bring bar to your chest raise straight up)
3) Behind the Head Shoulder Press (raise bar over your head and rest on shoulders, then raise straight up)
4) Curls (Palms up, bend elbows)
My routine takes 35 minutes, and if done in winter months, once or twice a week and not on consecutive days as muscles need time to rest and repair. I alternate with biking or walking as running is not good for you after suffering a heart attack. This is "anaerobic" exercise as opposed to "aerobic" exercise. I see people walking and carrying hand weights. This defeats the benefit of either type of exercise as you need to breath in a steady rhythm to walk, while you require explosive energy to lift weights. Exercising will help you regain strength and posture, definition, and a good mental attitude. It is also good for circulation and motility.
