Ya it's definitely on my list this season to improve the front brakes. Right now the back brake has as much stopping power I feel. I see dual front disks on allot of bikes and even basic little scooter looking things, and or a much bigger drilled front rotor. I'm going to start with the yamaha pad kit.
I've been reading and I see a preference for and against progressive rate springs. What is not to like about dual rate springs? Suspension is needed all around on my bike. I'm thinking to get basic inexpensive suspension this season. Unless I find something much better for a little more. I was hoping to spend no more than 200$ that's for front springs and rear suspension.
Also what are air caps? Thanks in advance for any input and all have a great weekend. My only riding will be to mom's. I'm trying to finish up a front porch. I'm doing railings sat, and figuring out a skirt. So wrenching will be a little at night. Think I'm gunna go ahead and put on the hd jcwittny chain.
Hi Joe,
main problem with the '77 & newer XS650 front brake is the master cylinder area is sized to work two disk calipers and
North American XS650s only have one caliper.
Fix 1) :- Replace m/c with one with a smaller piston.
Fix 2) :- Add the second brake disk & caliper.
Either fix will get you better brakes but don't stop there, swap in stainless brake hoses all round and drill all the disks.
The usual "progressive" spring ain't progressive, it's dual-rate.
It's soft until the tighter wound coils touch each other which makes the remaining coils work harder.
Rear shocks, swap 'em out for better ones "you don't get what you don't pay for."
Air caps let you increase the front fork's spring rate by pressurizing the air inside them.
OK on forks that were designed to have them,
(or like the Dowty Oliomatic forks on my 1947 Velocette, relied on air pressure alone)
of dubious worth otherwise.
