Help identify this please
Muneio
XS650 Argonaut
Santa Barbara, Ca
I've got the bike (81' special) stripped down to the frame and I'm in the process of removing un-needed tabs etc. But for the life of me I can't remember what this tab was for and I don't want to remove it, only to find out later I need it.
Thanks for any help you can give me identifying this.
Bill
Doubtful it is for the rear master cylinder, as the 1981 Special had a drum rear brake. I am quite sure that it is one of the mounting brackets for the security chain box.
Hmmm,
Yeah it's a drum brake in the rear.
What is a security chain box?
Thanks
Bill
Hi
just went out and looked at my 1981 XS650SE and yes it has that bracket, with a rubber grommet in it but is not used for anything. Mine is a drum rear brake also
Kev
The security chain box was a little plastic triangular box that held a vinyl covered locking chain. The chain could be used to secure the bike to a post or similar object, and used the same key as the ignition, gas cap, and seat lock.
Hi
Kev
Awesome, thanks Kev thats what I suspected but nice to have it confirmed. :thumbsup:
This is for the rear brake drum master cylinder for sure. It if for mag wheels on the special. I am certain of this as I have removed it not less than a month ago.
Alfredo, your bike must be a 1980 or older. A rear brake drum has no master cylinder because it is a ... drum brake. 1980 and earlier Specials (except for the 1980 Special II) were equipped with a disc rear brake that utilized a master cylinder.
I am certain it is a 78. I said rear drum brake master cylinder, but meant rear disc brake :(
Sorry about that. It had mag wheels with a rear disc and that mount was for the master cylinder.
Well either way I dont need it and it is now gone. But I now see in your pic of the chain security box what the other tab I took off the ugly gusset area was for. :wink2:
Thanks everybody
