louis
Hey guys, running a 1973 with stock pipes and air filters and (I think) stock carbs. I didn't trust my RHS carb because it had a broken and repaired float post.
Asked a local guru if he had any carbs for a 1973 and he sent me one, issue is, it doesn't have the two tubes that feed fuel between the two carbs. What did he send me (it's on the right in the photo). My old RHS carb is on the left hand side in the photo.
Can I run this RHS with my original LHS carb and just block the fuel tubes off using some silicone or something? I'm running two petcocks so I'm not sure why it would matter? Or are they just not compatible and I need to source the right year carb?
Thanks
Thanks
