You can get close by setting a piston to top dead center and see if the timing mark on the rotor aligns with the "T" on the stator. That's only as good as your ability to set a piston to TDC by looking through the spark plug hole.
I did a visual inspection, LH cylinder at TDC the mark was on the stripe. So I call it good for now.
Just did a testride with the new rotor and other reg rec.
Exactly 40minutes in, starts to stumble again. I can leave it running idle without it stalling. Revving it some times goes ok, and sometimes leads to more misfiring.
I popped the airfilters off, no difference
I removed the crank vent cannister, no difference.
I sprayed it with some deodorant around the intake barbs, hard to tell if something happens there. It's stumbling before I do it.
I'm throwing in the towel
Hi Jan,
Stator all 3 windings had around 0,5ohm no short to ground either
The charging is very strong, 14 at idle, the rest 14,5
Batt ign off after 40m 13.0v
It does seem like the rh cylinder is running out of sync compared to the lh.
Did a compression check now: both 135psi, warm with WOT
No kill switch on the bike
Fuses visually ok
New sparks plugs yes
Gonna try my old ign box. I know it doesn't advance but will seeView attachment 175049
So when the bike revs slow, one bad pulse is quite a lot and messes up the firing.
When revving hard, no problems because one bad pulse is now only a very minor part of the signals coming in
Not gonna lie, this feels terrible... All this effort, all this time and work
It's good that you have another bike. Put it all behind you Bjorn and just enjoy your trip. When you get back, have a read here. @Team Junk has discovered that a Suzuki GN250 ignition box is most likely a viable replacement for the TCI box at a cost of about $20 here in the states. I'm running one in my 80SG and so far so good.Not gonna lie, this feels terrible... All this effort, all this time and work
So we made it to Luxembourg! Don't ask me how. First few hours went great! But that after the first long stop it would start but just die because no spark. This would go on and off. Somehow it kept going but it makes me Hella nervous. Note that the tacho would keep working, so the system doesn't die complete
Higher speeds would go ok. But usually after stopping no Matter how short, it would act up.
The last few 20 km were nerve-wracking, I can tell the bike is not running good. It's not popping but I see the tacho vibrating. It didn't do that the first part of the trip. Note that it's a new tacho that uses inductive sensing of one plug wire.
I brought a shit load of tools and a backup reg rec. But that's it.
If anyone has some suggestions, I'm all ears!
My instinct says it either a wiring problem
