1. Dismiss Notice
    Dismiss Notice
Wanted - Help - stater button
Discussion in 'Classifieds' started by Scripto VU, Jul 14, 2019.
  1. Scripto VU
    Scripto VU Dukes Speed and Custom
    60
    486
    53
    usa.
    I realized when working on my wiring harness.
    That I am missing the starter button .Any ideas ?
    1974TX650A. All original handle bar switches
  2. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    NOTE: the handlebar MUST be grounded (earthed) for either the starter or the horn to work.
    This may not be obvious to everyone - but if you set your multimeter on ohms (looks like a horseshoe) and touch one probe to the handlebar and the other to the negative battery terminal - or to the top of an acorn nut on the engine cylinder head or to an exhaust stud acorn nut - the meter should jump to 0. If it doesn’t, check the grounding of the bars and fix it or nothing will work.
    This ground connection of the handlebars is accomplished in several different ways and all are vital:
    1. There is normally a little ground wire from the wiring harness to the underside of the stud that fastens the handlebar mount on the LH side (just under the speedometer).
    2. Also - the parts of the bars that are secured by the clamps to the upper triple-tree MUST not be painted. They must be bare (usually chromed) metal and those clamps must be clean and tight.
    If the handlebars on an XS650 are not grounded - you have a problem - and you must fix it before moving forward with wiring.
    The other gotcha in the starter circuit is the starter safety relay (SSR) which prevents you from engaging the starter with the engine running (which would destroy all those cute little gears). The SSR lives under the right hand side cover in a little metal cover. The relay can become corroded and if that happens, your starter will be dead as a doornail.
    NOTE: do not jumper the SSR - it is an important safety feature of the bike and you need it to keep you from wrecking your starter and possibly filling your engine with broken gears and other metal debris.
    To clean the SSR - just remove the little cover (two VERY tiny screws - don’t loose them!!) and carefully clean the contact points with a business card or a small piece of fine sandpaper. You might want to give the whole thing a little squirt of electrical contact cleaner too. Then button it back up and try the starter.
    I clean the SSR on Lucille about once a year just to keep things “happy”.
  3. Gator xs2
    Gator xs2 XS650 Addict
    397
    842
    93
    FL
    I had a cb500four back in the day and lost the button. I routed the wire out of the switch and used the handlebars to start it. Problem solved. I think it did shock a little in the rain though.
    Scripto VU and MaxPete like this.
  4. Scripto VU
    60
    486
    53
    usa.
    Thank you for the valuable information, you probably saved me many frustrating moments !
    peanut and MaxPete like this.
  5. I put a ticket switch on mine for my starter it works great
  6. MaxPete
    Ticket switch?
    Whaddat?
    TwoManyXS1Bs and Tim Meaders like this.
  7. Scripto VU
    60
    486
    53
    usa.
    I had difficulty getting on Mike's site (par)
    Ordered a starter button from 2Fast Moto in California. Will let you know what I get.
    MaxPete likes this.
  8. Rocker switch stupid auto correct
    MaxPete likes this.
  9. jetmechmarty
    jetmechmarty XS650 Guru Top Contributor
    Mailman likes this.
  10. solo2racr
    solo2racr Suck, Squeeze, Bang, Blow
    Had to click to see what a STATER BUTTON was. :shrug:
    gggGary likes this.
  11. I guess nothing lasts forever......
    gggGary likes this.
  12. Mailman
    Voted best ignition switch, and coolest dash. It’s what my XS2 wants to be when it grows up! :)
    peanut, Team Junk, gggGary and 5 others like this.
  13. MaxPete
  14. Mailman
    Team Junk, gggGary, Jim and 2 others like this.
  15. TwoManyXS1Bs
    Haha, lookit all them steam gauges.
    That reminds me.
    I have a "rudder trim" knob needing a home... :D
    gggGary, Jim and Mailman like this.
  16. ThatXS650Guy
    ThatXS650Guy More Sparky than Speed Racer XS650.com Supporter
    When my starter button was acting up I ended up running a separate ground from the housing to the frame. Been 100% since...
    Tim Meaders and MaxPete like this.
  17. Thats so badass wats that on
    gggGary likes this.
  18. Gator xs2
    397
    842
    93
    FL
    I think it’s the cockpit of the Millennium Falcon.
    MaxPete likes this.
Share This Page
