lopejd01
ok so PO did not have anything wired to this bike. there was no headlight,speedo/tach, signals, left bar switch, nothing. there is a right bar switch and it looks like all the wiring is there. I have a huge spaghetti pile under the top tree.
I'm trying to wire everything to this bike but following these wiring diagrams is hurting my head as I have all this mess of wires and cant figure out what to hook them to. refer to pictures- I circled two wires that I found are the feeds from the right bar "on/off" switch. I'm thinking I can just wire the headlight,speedo led,and tach led to these two wires and that way I will have them all powered when I flip the switch. Signals on the other hand are causing me confusion. I'm using the two wiring diagrams pictured, the original one is confusing since I'm not running any signal indicators and all my electrical components are aftermarket. The second wiring diagram is much simpler but would really only help if I was rewiring the whole bike.
so basically, I need to figure out where to wire the pillbox and than where to wire the signals. I'm trying to figure out how to do this by using the stock spaghetti pile I have under the tree. Oh, and the signals I'm using are tiny led's that are self grounding and only have one pos wire (if that makes a difference)
any help would be appreciated
Bike is a 77'
Bike is a 77'
