1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
help
Discussion in 'The Garage' started by manduria, Aug 11, 2015.
  1. manduria
    manduria XS650 Enthusiast
    33
    0
    6
    italia
    I have restored a xs2 ' 72, but I have a problem: the starter motor runs fine, spins the wheel also indicated with the arrow in the picture attached, but do not turn the Pistons ...
    What could be the problem? with the start-up pedal start
    am.denapoli@libero.it
  2. XSLeo
    The starter motor turns that gear you show, that gear turns a shaft that runs across the engine. This shaft spins a small gear that turns the bendix gear set behind the clutch.
    As the shaft turns the bendix a wishbone shaped spring holds the gears from turning, this makes them slide over to engage the crank. This turns the engine.
    Most often when this fails the spring is weak.
    A search for starter fixes will lead you to threads telling how to fix this.
    The kick start pedal does not use any of these parts. The kick start engages gears in the transmission and turn the engine through the clutch.
    So to use the kick start you have to put the bike in neutral, let the clutch lever out, then kick.
  3. manduria
    33
    0
    6
    italia
    thx LEO ,
    DO YOU HAVE A PICTURE OF THIS WHELL ? CAN YOU GIVE ME MORE DETAILS ? I HAVE TO OPEN RIGHT CARTER THEN ?
  4. peanut
    peanut XS650 enthusiast & inveterate tinkerer Top Contributor XS650.com Supporter
    4,043
    2,677
    263
    England
  5. XSLeo
    I don't have any pics but inxs has done threads on several systems.
    On pics the best I can do is tell you to look in your repair manual. Clymer's book page 43 shows the kick start. In the pic you see the shaft the pedal goes on. You see it engages gears in the tranny that engage the clutch to turn the engfine. Page 86 shows the gears and cross shaft of the starter system. the gear #12 is what you see in your pic. Gears #20, and parts 15 to 22 are mounted on the cover #23.
    The gear on the starter engages #21, this engages through the bushings #19 gear #20.
    #20 engages gear #12 on the shaft, the shaft engages gear 11 that engages gear #5. As this gear spins it causes gear #4 to spin, the spring clip #3 holds the gears from turning and slide out on the splines on part #1. This causes gear #4 to engage the crank and spin the engine.
  6. manduria
    33
    0
    6
    italia
    thx very much PEANUT, your link its fantastic and i have resolved my problem
  7. peanut
    4,043
    2,677
    263
    England
    excellent !
    thank you for updating the thread .:thumbsup:
Share This Page
