Like the title says, when I hook up the green wire coming from my regulator to the positive brush on the stator the voltage at the battery drops to 9.5v. (my battery is brand new and fully charged, and reads 12.6 volts when the green wire is un-hooked and when the battery is out of the bike)
The voltage at the battery, ignition switch, main fuse, and regulator feed all drop from 12.6 v to 9.5 volts when I hook up the green wire. (my regulator is brand new, and I have tried it with both a new mechanical and solid state regulator)
I also did a regulator bypass, by completely unplugging the regulator and using a jumper wite from the battery + to the positive brush of the stator. I still get the bike wide drop from 12.6 v to 9.5 v. This drop happens regardless of whether the stator is plugged in (the plug with the 3 white, 1 red, and 1 black wires).
The resistance across the 3 white wires checks out. I read that there should be infinite resistance between the white wires and the stator housing, but on mine i get readings of 20-50 ohms.
I tink my stator is shorted / grounded out. Has anyone experienced something like this???
Thanks
Thanks
