Ok I understand what item in the pic is a plumb bob .. but out of all of my mechanical schooling / college and weekend classes I have not the slightest clue as to WTF a plumb bob is .. would you care to elaborate its purpose ?
couldnt you just dull the point on a bench grinder and re angle it ?
A plumb bob is attached to a string and hung in a position where it is desireable to place a perfectly vertical, square line. They are used in survey work and masonry extensively. I use them on aircaft to determine if the aircraft is still geometrically sound. You establish the centerline by dropping the bob from pre-determined points at the front, back, and in the middle. Then you drop from symmetrical points on the wings and tail, and measure the distance to the center points. If the lines are quartering forward or aft, you can tell if the wing is still straight in relation to the fuselage. Numerous other determinations can be made, but this is an example.
On the riveter, something like a roll pin punch does a better job of evenly driving the flange outward on the link pins. 40 degrees sounds like it will be much too steep to flare it out enough. Compare your finished diameter to a factory pin. It should be about 15-20% wider for a good installation. If your new chain came with spacer plates, you can tie them in place with a twist tie. You will want to make sure they are in place when you push the side plate on, and when you rivet. If not, you can pinch the side plates too tight and cut the o-ring, or X-ring, or whatever ring you have.
Good luck. Also, Cycle Gear has a nice press/riveting tool right now for 29 bucks with any other purchase. You can do without it, but if you have more than 1 chain driven bike, it's well worth it.
Thanks for the replies, I was thinking it was to sharp an angle, guess It'll be plan B when I work out what it is. In Aus you're up for $ 70 to a $100 for a proper set.
anyone know of a good homemade valve spring compressor? i was able to get the collars off with some notched out pvc and c-clamp, but getting them in is going to suck....
Just checked the Cycle Gear site, thought "you beaut" proceeded to checkout, $50 to ship to Aus so It's back to $80.
Shipping to Aus seems to have gone through the roof.
Tks anyway.
Tks anyway.
Pete, I always admire innovation, but in this case you should do an estimate of the cost of having the chain come loose at 100 KPH.
I splayed the end of mine with a hammer, backed by a steel block. In fact, I did that twice in 2011. No problemo.
I saw a pic of somebody using a nut cracker tool to splay out one end. Don't know if it's advisable, but it's better than rigging a similar tool from scratch. My thought is it would at least as well as something hitting the chain, with a block on the other side, all floating in air.
http://www.chain-auto-tools.com/general_auto_tools/AMR713L.htm
all i know is i spent alot of time messing around with home remedies for this one. none really worked to my liking. 30 seconds with the tool and it was done and i was very confident. also helped to push the link out when i needed to remove the chain as well. sometimes its better to bite the bullet and get the real stuff.
on that note, anyone know of a good homemade valve spring compressor? i was able to get the collars off with some notched out pvc and c-clamp, but getting them in is going to suck....
Plumb bob for vertical? Nahhhh. I use a pair of Hugh's eyecrometers.
Im sure someone could ship it to you for cheaper .. I just shipped a glass headlight there(AU) for around 20$ .. weight would be comparable .. if not more
