sseres
XS650 Junkie
everything has been fine since I last posted about my clutch, maybe 200 miles ago. Riding around on what was going to be the last day before the rains return here, it was low 80's out and I was on surface streets.
Suddenly, i was being pulled a little at a stop light, like the clutch was suddenly out of adjustment (more than the odd clutch worsens as engine warms up thing), but just a little.
I have the 650central ez pull clutch cable that i put on last year (HIGHLY recommend this over a standard cable). I tried giving it a little extra turn at the handle grip, but noticed that I was at end of the threads. I thought maybe it was just one of those "old bike" things and would certainly be better by the next traffic light.
Wrong. a few minutes later, I noticed that the clutch lever was wiggling! I grabbed it and it had no resistance. I thought nuts ,the cable snapped! I pulled over and wiggled some things (you know, like I knew what I was doing in case anyone was looking) and I realized the cable was intact. There was just no engaging the clutch, like at all.
I got lucky and got it popped into 1st and drove home while keeping RPMs under 3500 or so. I popped off the LHC expecting to see I don't know, a stretched cable? a smished up worm drive? the adjustment screw having fallen out? Spring popped off? Plastic track for the worm drive cracked? Not that I could see. Looked as good as when I put it in earlier this spring (with a new one from Mikes). The clutch has been freaking solid all summer, I swear.
I know I need to get into the RHC, but it's a messy job and I haven't had a lot of time to get out there to do the job that needs to be done. I guess my question is what do you guys think I'm likely to find? I didn't hear any parts rattling while I was driving home. I have the single piece push rod and it looks just like it's supposed to, and moves freely through the gasket on the left side.
Anyway, just looking for predictions. I have a lot of spare clutch parts (boss, baskets, and bolts) so I think it won't be tragic to fix if something actually broke. I just can't for the life of me think of what's causing this weird symptom, unless indeed the cable did stretch an inch and I just can't tell.
thanks as always!
thanks as always!
