+1 on the stock tci working a treat, and is fired by the crank. I will more than likely my next xs will be 80 or above for that reason..and in my mostly stock bike the bs34s are fine as well with a little adjustment
..I want to get like an 83 with the choke cable repaint it and keep it stock looking then play with my 80 lower it maybee mono shock...
I totally get it though if you have $ budgeted for the bike and want it a certain way. Just my point is the tci is not bad.
Hooser, that looks like a really solid system that power dynamo, Just to be sure, it can be used with the standard 12v battery, electric starter and lighting correct? Also can you post a link to the carb system you put together? Curious to what carbs you use for it.
