Installed pods, have question.
Many of us install a cheap power brake check valve and poise it over the pod .....
These are available in the "Help" section of most auto parts stores for about $5 .....
Found that one side of the "Y" shaped metal vent had a factory rubber plug installed even though the tube running to the airbox was hooked up. Was this a mistake at the factory? Do I just need one tube running to the power brake check valve & leave the plug in or remove the plug and run two? Thanks for the tip on the setup:smart fix for the pods. Joe
You can just run one if you like. Your model had one side plugged. My '78 had both sides open but with reducers in them, so they probably add up to the same as running just one fully open.
