B Burdine97
Hello guys i recently got a set of drag bars (27.5" Length, 0" Rise, 3.75" Pullback) from mikesxs for my 1981 special and began to install them. Everything was going great, I rerouted the clutch cable as seen on previous threads, I went to mount the master cylinder, but then began to run into an issue. The master cylinder hits the tachometer, not allowing enough room for the throttle sleeve to be installed all the way on the bars. The throttle sleeve sticks out about an inch, so i need the master cylinder to move in about an inch. I have thought I need to either remove the tachometer, or make some mounts to raise it up a bit, allowing the master cylinder to slide in more. Does anyone have any different ideas or recommendations? Here are some pictures. Thanks!
