Intake manifolds
Gator xs2
FL
whats the procedure to reinstall the intake manifolds?Thanks
I like to use factory or factory type gaskets because they are quite thick. I think this helps with sealing but also with heat isolation, as in keeping the engine heat away from the manifolds and carbs better. Some aftermarket manifolds come with new gaskets but they're very thin paper. I won't use those. I apply a small bead of sealer to one side of the gasket, the manifold side. This is not so much for sealing but rather so that the gasket comes off with the manifold any time I remove it, and doesn't stay stuck on the engine. Since the gasket is so thick, several re-torques of the mounting screws is usually required before they hold tight (due to gasket compression).
A light sanding probably wouldn't hurt. I also like to replace the Phillips clamp screws with Allens. Many of the originals are all buggered up now because they are J.I.S. and no one back in the day had the right screwdriver. You can't tighten them fully any more, and the clamps need to be really tight.
Although the originals are longer, I find a 16mm long replacement works fine.
