1. Dismiss Notice
    Dismiss Notice
Is it my turn? Anything to do with lathes, mills and other shop tools
Discussion in 'The Garage' started by gggGary, Dec 2, 2017.
  1. Downeaster
    Downeaster Everything in XS Top Contributor
    [​IMG][​IMG]
    Truck finally showed up with my new toy. Spent the last few hours assembling, inspecting and cleaning. According to the Ewe Toob videos, most of these Chinese lathes need a lot of tweaking and adjusting to run well. The most egregious problems noted in the videos are slop in the cross feed and compound and the belt drive not tracking true.
    As far as I can tell, none of these things are an issue with mine, at least so far. Crossfeed and compound are tight with no detectable slop found via the "grab it and wiggle" test. Belt walks around a little but runs in the center of the pulley. Travel on the crossfeed is a little stiff, but I probably don't have all the cosmoline out from under the ways yet.
    Fired it up and the chuck appears to run true with no noticeable vibration. Once I finish cleaning up, I'll indicate it for runout to be sure. Also need to check the tailstock with a dead center and see where it lands.
    Of course it ships with squat for tooling, so I'm about to hit Amazon and beat the crap out of my VISA card. :confused:
  2. gggGary
    TwoManyXS1Bs and Jim like this.
  3. Downeaster
    Oooooo, thanks for the banggood tip.
    I think...o_O
    Jim and gggGary like this.
  4. TwoManyXS1Bs
    Is that the G8688, 7" x 12"?
    How about "backlash"?
    More temptations:
    https://littlemachineshop.com
    http://www.cdcotools.com
    http://www.gadgetbuilder.com/index.html
    http://www.micro-machine-shop.com
    Jim likes this.
  5. Downeaster
    Yup.
    Didn't think to check for backlash, I'll do that today. Lubed the handwheel gearing on the cross slide with a little CLP, moves quite a lot better.
    Jim likes this.
  6. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    That looks like a nice little unit DE - congrats!
    On tooling - my lathe mill uses a certain Morse taper (MT3 I think) and so anything with that taper can fit. I found a fair bit of stuff used here and there.
    Perhaps if you can determine the tooling geometry of yours, you’ll find some good stuff too.
    Jim likes this.
  7. Downeaster
    Yup, tailstock is MT2. I've ordered a Jacobs chuck for it, among other things. Thinking about ordering a spring collet holder and a set of collets. Need to put some miles on it first. Also need to order various cutting fluids (Tap Magic, A9 for aluminum, some Kool Mist or the like for steel). As noted earlier, the lathe itself was probably the cheapest related purchase...
    Jim and MaxPete like this.
  8. MaxPete
    Indeed - sort of like “the barn find was the cheapest part about getting this old bike going...”.
    I’m sure I’ve spent far more on Lucille AFTER I got her than she cost to bring home in the first place. Still, it has been worth it in my view.
    Jim and YamadudeXS650C like this.
  9. peanut
    peanut XS650 enthusiast & inveterate tinkerer XS650.com Supporter Top Contributor
    4,054
    2,690
    263
    England
    You're a bit light on shop equipment there Jim :) :lmao:
    Could I ask what portable DIY /Hobbist TIG you guys would recommend ?
    I need something to weld butt weld 1mm -1.6mm steel panels . i have a Mig but its difficult to spot and seam weld 1mm steel sheet with a Mig and not get distortion and blow through
    Jim likes this.
  10. gggGary
    I turned a chunk of aluminum last night. after some head scratching .
    Decided this showing basically 0 deflection wasn't telling me anything. So got the caliper and came up with about a .014" larger diameter at the tailstock end. To go with that the tailstock appears to have the cross adjustment way out of whack. The good news is the adjustment is pretty straightforward. I'm going to want to check comparative height as well.
    I am third owner and now suspect I can trust nothing. guess lathe PO's aren't much different than motorcycle PO's
    One of these days I'll tell a story about picking up this lathe. :confused: :cautious: :eek:
  11. gggGary
    Living in the great lakes region this kind of stuff shows up on CL all the time.
    [​IMG]
    he's asking $750 and will load on your trailer. LOL
    YamadudeXS650C and Jim like this.
  12. Jim
    peanut likes this.
  13. peanut
    4,054
    2,690
    263
    England
    thank you Jim. Unfortunately I cannot justify that kind of money now that I'm retired. I'm looking for a solution at around half that price if its possible.
    I've been looking at the small portable DC inverters but I'm not sure which can be used with the small torches like this one torch.jpg
    Jim likes this.
  14. gggGary
    Some of those little scratch start tigs work fine. I have one now but need to make a threaded adapter for the gas inlet, it has an oddball thread.
    peanut and Jim like this.
  15. peanut
    4,054
    2,690
    263
    England
    nightmare !... why the industry cannot agree some standardization is beyond me. I think we spend more time researching compatibility of equipment accessories and connectors than we do the actual equipment.
    I have this mini inverter which is amazingly good. It will weld 5mm with good penetration but I don't think I can use that type of torch with it can I ? osaki.jpg
    Jim likes this.
  16. Jim
    Peanut,
    this TIG welder can be had for a little over 200 bucks. It's dual voltage and takes your 50hz lectricity'. I suspect that by the time you buy all the stuff you need for your inverter, you'll be around that cost anyway.
    I've never used a Zeny TIGger, but I do have the Zeny plasma cutter and it's good quality.... for Chinese stuff anyway.
    peanut likes this.
  17. peanut
    4,054
    2,690
    263
    England
    thats more like it Jim ;)
    Its probably only going to get maybe a few hours use a year so its not worth spending £600-£700 +
    I have a lot to learn about Tig welders MMA, HF , Lift arc , AC ,DC, :umm:
    Jim likes this.
  18. Jim
    And that my friend... is half the fun of doing it... the learning. I always told my students that it's a sad day when you never learned anything. That applies to us old folk too:)
    MaxPete likes this.
  19. kshansen
    kshansen XS650 Junkie Top Contributor
    883
    3,041
    243
    Just out of curiosity, would this little TIG be something that wold work for welding stuff like fabricating exhaust or other thin steel like that work? Will it run on say a 20 amp house outlet?
    I do have a little Lincoln 120 volt MIG with the gas kit on it that I play with once in a while. What woould be the advantage of the TIG over a MIG? Sorry to be asking such basic questions, but one has to start some where!
    Jim likes this.
  20. Jim
    Yes it will. As to advantages, that would be too long a reply for here. Main reason is better control of the power which translates to better heat control on your workpiece. Yes, it works great for exhaust tubing. Google TIG vs. MIG. All will be revealed;)
Share This Page
