They look good!
Was hoping to. From what I can tell this should take the place of the two rubber lines.I can’t tell from that ad, are you replacing your stock two piece lines with one new stainless?
79s have a different caliper.I used a $10 ebay one on my 79 standard. 1 piece 80cm.
Pete save some for me!
I would be tempted to crank the motor over to put the piston at bottom of stroke with valves loose on the bad cylinder and put some air pressure into that cylinder.
If all the air comes out the exhaust then it is a problem with exhaust valve, stuck or burnt.
If it all comes out the intake then, yep bad/stuck intake valve.
If it all comes out the dipstick hole, not good!
Did a leak down test. Air coming out exhaust valve.
Possibility. Or take parts from another 256 engine I bought. I'm not a big fan of using used parts but I might. Going to get it apart, take stuff to machine shop and see what I have. The machine shop I will be using is one I worked at part time 30 years ago. Owner now worked there with me then.Swap heads?
I had read that. That's why I was hoping the "snake oil" would do something. Since the engine is out probably best to freshen it up.Check for a chunk of carbon on the valve seat. Sometimes it's simple. http://www.xs650.com/threads/the-meatball-mechanic-low-compression-fix.11693
Lycoming has a procedure they call "staking the valve." for carbon buildup. Bring it to TDC, put 80 pounds of air in it, lay a piece of wood on the tip of the valve stem and smack hell out of it about a half dozen times. I've cleaned up many a carboned exhaust valve "staking" it.Check for a chunk of carbon on the valve seat. Sometimes it's simple. http://www.xs650.com/threads/the-meatball-mechanic-low-compression-fix.11693
Interesting procedure. I think I will try that before I pull the head off. Only problem is the leak is so bad I can't build any pressure in the cylinder. But worth a try.Lycoming has a procedure they call "stalking the valve." for carbon buildup. Bring it to TDC, put 80 pounds of air in it, lay a piece of wood on the tip of the valve stem and smack hell out of it about a half dozen times. I've cleaned up many a carboned exhaust valve "staking" it.
