1. Dismiss Notice
    Dismiss Notice
Jet kits
Discussion in 'The Garage' started by Oprahands, Dec 5, 2019.
  1. Oprahands
    Oprahands XS650 Member
    Ive been trying to find a jet kit for my bar I carbs so i could try a bunch of different jets to get my bike running right. Its very rich at the moment and i dont want to pay 10 bucks for every single jet id like to test
  2. grizld1
    grizld1 Grumpy old man Top Contributor
    Welcome! You'll find many posts on this, but most kits are generic and contain bits and pieces that don't work for the application listed. You can usually trust only the float bowl gasket and float valve assembly, and sometimes the float valve seat is hinky. Avoid Keyster, lots of Chiwanese junk in those kits. Individual bits of genuine Mikuni parts look like they'll cost more, but at the end of the day you'll save time and money with them. Click the Tech button and find the link to the XS650 USA carb guide; year-by-year carb identification and components are there, and you'll be able to identify the parts you need. My favorite source for Mikuni brass is Niche Cycle Supply.
    gggGary likes this.
  3. Oprahands
  4. gggGary
    :agree:
    :thumbsup:Niche cycle and genuine mikuni. :thumbsup:
    bar I carbs????
  5. Oprahands
    Sorry i think i tried to type bikes carbs but my thumbs don like working sometimes. Theyre mikuni bs38's
    gggGary likes this.
  6. 5twins
    18,873
    9,711
    688
    You'll need to narrow down the carb set I.D. better than that. There were 4 different sets of BS38s used on the 650 during it's production and they were all jetted differently. You base your re-jetting on what was stock for the year of the carb set, not the year of the bike .....
    [​IMG]
    gggGary likes this.
  7. Oprahands
    Thanks 5twins! The chart helps a lot. Been reading your stuff on here for a while now actually and it helps.
  8. 5twins
    18,873
    9,711
    688
    For the usual "pods and pipes" mods many of us do, some minor re-jetting may be required. But we're talking just some small size increases, like one up on the pilots and one or two up on the mains. The exception is the '76-'77 carb set with it's very small 122.5 main. The one size increase for the pilot will hold true but for the main you may need to go 3 or 4 up instead of just 1 or 2.
    gggGary likes this.
  9. Oprahands
    The to g is though is its running really rich with stock jets and pod filters
  10. gggGary
  11. gggGary
    How does it run with the filters off?
  12. gggGary
  13. Goldenboy
    Goldenboy . XS650.com Supporter Top Contributor
    gggGary likes this.
  14. gggGary
    Wow I never would have guessed.
    Goldenboy likes this.
  15. zodc
    zodc XS650 Enthusiast
    Is that the same for BS34s or are these basically the same through the years?
  16. zodc
    Nevermind... I just realized you posted the specs in my carb thread and BS34 is at the bottom. :)
    gggGary likes this.
  17. 5twins
    18,873
    9,711
    688
    The BS34s were changed a little bit compared to the BS38s but they remain very similar. Jetting changes required for mods remain pretty much the same as well. On my '83, I have pods and quite open mufflers. I'm one up on the pilots, two up on the mains, and one down on the air jet. The air jet is another tuning "tool" for the idle circuit.
    [​IMG]
    [​IMG]
    [​IMG]
    zodc and gggGary like this.
Share This Page
