Square Circle
Okay, im going to ask this same old question for you expert carb guys.. Seems as if a alot of things contribute to the way a carb is jetted by what is modified with engine..
I have a 79 with bs38 carbs, I am looking to use the K&N pod filter " knockoffs from mikesxs." I already have them.. My carbs are totally cleaned out and floats set correctly at 24mm each, and are stock jetted at the moment..
After briefly talking with MMM with 650 central about this, he mentioned that a typical jet set up is 1 up on the pilot (27.5 to 30) and 3 up on the main(135-142.5?)...The 3 up on the main sounds like a lot to me, as I am still running stock exhaust . I will be adjusting my cam chain and valves shortly , and checking timing soon when i switch to a pamco ignition with the high output coil and iridium plugs.
In your experience guys, what is the most usable and functional jet setup for what i have?
