Nice workaround Jim! Good job.,
Yeah.... still waiting on some carb parts..... but close enough I can almost smell the fumes.dang you’re getting close to firing that thing up.
Yeah, good point. The tensions pretty light. Only the thickness of the washers and I glued the seal in when I put the motor together, so I'm not concerned. But if anyone else does this and they're not sure the seal will hold up, you might want to consider a fender washer on the inside so the load is transferred to the case and not the seal.If so, you should probably keep an eye on the pushrod seal and make sure it doesn't get pushed in more.
You mean like this Pete.....Ideally, a small bellows (like a small fork gaiter) would also be good and it wouldn’t transfer any measurable load at all. I am not sure where such an item could be sourced
