1. Dismiss Notice
    Dismiss Notice
Jim's 1980 SG Miss September
Discussion in 'The Garage' started by Jim, Sep 26, 2017.
  1. Paul Sutton
    Paul Sutton Sprained Ankle Top Contributor
    Confession: After several tries to get that rubber piece on I made a short taper on the lathe. The widest end matched the diameter of the metal piston shaft and the thin end matched the diameter of the rubber thing. With the rubber piece on the narrow end I placed the taper against the shaft and held it all in the vice. With some brake fluid to lubricate I push the rubber up the taper and it expanded nicely and popped onto the shaft. Then I spotted I had put it the wrong way around so had to remove it and start again.
    Good to know that an o-ring does exist out there - Thanks kshansen.
    MaxPete, gggGary and Jim like this.
  2. Jim
    Taming the Spaghetti Monster.
    I used Gorilla Tape to fasten all the connectors inside the bucket. Unfortunately, I forgot to take a pic.... and no.... no I ain't openin' it back up. :rolleyes:
    Tested again and everything still works.
  3. robinc
    robinc Member of the 'yellow meter gang' Top Contributor
    :lmao:
    :thumbsup:
  4. Paul Sutton
    The headlight bucket could do with about 10 tabs for ties securely glue inside to help with organization. Maybe a future project????
  5. Paul Sutton
    Jim, is that voltmeter mount polished Aluminum or something chromed? It looks very smart there. In fact so smart I feel jealous!! I've never seen it from behind and below before.
    gggGary, Jim and robinc like this.
  6. Jim
    Paul Sutton, gggGary and robinc like this.
  7. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    I’ve always been puzzled by how shallow the headlight bucket is. If they made the darned thing 2-3” deeper, life would be SO much easier when doing the wiring and as far as I can see, there isn’t any reason at all why it couldn’t be deeper.
    I’m currently searching for a deeper headlight bucket (but standard 7” diameter) for my cafe bike - anybody found a source?
    robinc and Jim like this.
  8. 5twins
    20,063
    12,019
    813
    The bucket from an XS850 Special might be an option. I don't think it's much deeper overall but it does have a rather pronounced bulge on the bottom that may help .....
    [​IMG]
    [​IMG]
    [​IMG]
    The headlight is the same size as the 650's, that's what I bought it for. Cross-referencing part numbers showed me that the chrome ring was the same which means the headlight had to be the same size, and it's an H-4. That's what I was looking for, a factory H-4 I could swap in. This deal came along on eBay, $25 for the whole bucket, so why not. Aftermarket H-4's alone usually cost around that. The only "glitch" I ran across is that the side-to-side adjuster screw for the lens is angled differently in the 850 bucket. You need to use it as the straighter 650 one won't fit in there. The other small mod that would be required is re-working the bottom "tilt" bracket. The 850 bucket mounts the tab for it in a slightly different spot, off to the side more.
  9. 5twins
    20,063
    12,019
    813
    One more thing about that 850 bucket - it doesn't use or need rubber grommets on the wire loom holes, the edges are rolled over and not sharp.
  10. Jim
    Front Master Cylinder.
    Scrubbed the master cylinder in the stoddard tank. Taped up the inside bits and bead blasted it. Wire brushed the inside and scrubbed it again....
    Painted it with VHT gloss and baked at 175F for 2 hrs.. Put it all back together with a K&L rebuild kit....
    MrBultaco, Paul Sutton, Meddy and 6 others like this.
  11. Mailman
    :whistle: Super nice work! Color me impressed !
    You always take it to the next level!
  12. Jim
    Thanks Bob. Jus' givin' you a target to shoot at... ;)
    Paul Sutton, Mailman and robinc like this.
  13. MaxPete
    Nice - anybody got to be they’d like to part with?
    Please PM me if you do....
    Pete
    Jim likes this.
  14. MaxPete
    Jim: whered’ya get that snazzy MC cover with the Yamaha logo?
    Me likey....
    robinc, Jim and azman857 like this.
  15. Jim
    Can't remember Pete. Was about a year ago. Let me think on it...
  16. Jim
  17. MaxPete
    Cool! Thanks Jim.
    Jim likes this.
  18. Paul Sutton
    Jim, very nice work - again! How well does VHT stand up to brake fluid. I ask because I need to redo my virago MC on the XS. The previous coating I used did not cope well. Thank you
  19. 5twins
    20,063
    12,019
    813
    They actually have special caliper paints now, available at most auto parts stores. They are heat resistant and I would imagine they aren't affected by brake fluid as readily as normal paints. I've used them on cars but not on a bike yet. They come in spray cans and brush cans.
    59Tebo and Paul Sutton like this.
  20. Jim
    Thanks Paul. I used Q-tips to lubricate the bore and seals, so I managed to put it together without gettin' any fluid on the paint. If I do spill when I bleed it, I'll put a comment up here on how well it holds up.
Share This Page
