1. Dismiss Notice
    Dismiss Notice
Jim's 1980 SG Miss September
Discussion in 'The Garage' started by Jim, Sep 26, 2017.
  1. Paul Sutton
    Paul Sutton Sprained Ankle Top Contributor
    Just been searching out caliper paints and "VHT Caliper Paint" seems to be a good choice as long as it gets the heat cure which Jim mentioned above. So I will get some and do both my caliper and MC when Winter puts a stop to riding.
    MaxPete and Jim like this.
  2. Jim
  3. robinc
    robinc Member of the 'yellow meter gang' Top Contributor
    More Garage Art!
    Jim likes this.
  4. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,225
    4,082
    263
    kansas
    Looks great! Would look better if you drilled some holes in that bracket.:thumbsup:
    robinc and Jim like this.
  5. mrtwowheel
    mrtwowheel Honda Etched On Brain Top Contributor
    If you drill holes in the bracket.....then you'll have to drill holes in the rotor...….then you'll have to shave the legs....it will never end. My wife shaved her legs and wrecked 'em.
    Scott
  6. halfmile
    1,225
    4,082
    263
    kansas
    Yeah your probably right. My girlfriend shaves her legs and rectum too.:laugh:
    lakeview, Jim and mrtwowheel like this.
  7. Paul Sutton
    Jim, have you ever considered clear coating polished aluminum to save on future polishing time? In the UK they put salt on the roads in Winter and this really marks the raw polished aluminum if not cleaned off straight away. There must be a good coating out there somewhere (?) because I used an ordinary clear varnish in a spray can years ago (1985 - old technology) and it worked but softened a bit on hot parts and would get marked from the foot rubbing near the gear shift/back brake. There are these UV and solvent resistant 2K clears in a spray can now and they may be a bit more tolerant of temperature. At present I just wipe the polished Aluminum with WD40. Perhaps someone else has experience with clear coats?? Perhaps there is a very good wax preservative that works well on cool parts??
    Edit: http://www.xs650.com/threads/protecting-polished-aluminum.13027/#post-131749
    Jim and MaxPete like this.
  8. Nice work on the caliper mount there Jim, you've been very busy there.
    Jim likes this.
  9. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    Clear powdercoat. Calipers brackets and lowers were powdercoated 20? years ago, wipe off dirt and brake dust, shiny again. The rim and fork brace require regular polishing.
    Too bad I'm too cheap to do this myself........
  10. Jim
    Front Brakes... Done.
    Didn't get any pics of in progress work, but I treated the calipers the same as the master cyl.... bead blast, VHT paint, oven... all that good stuff. Seals were all good so I reused them. Piston had very minor pitting so I elected to reuse it (fingers crossed). The PO had put new pads in to try to get the brakes working, so I reused them.
    If you've never used Gary's bleeding method, you don't know what you're missing. I filled the caliper and line with fluid, then carefully pushed the piston into the caliper. Loosened the master and adjusted it 'till it was pointing downhill and connected the line....
    Set the caliper on a stool with the banjo fitting pointing straight up, then started gently pushing the piston in....
    Pushing the piston in forces the air up and out of the reservoir. Add a little fluid and pumped the piston back out.... pushed it back in.... rinse and repeat as necessary 'till the air bubbles stop coming out the reservoir. Adjust everything to it's proper position, topped off the fluid and screwed on the cap... and we now have a good firm brake lever.
    Guess the rear's gotta wait for parts.....
    Gator xs2, Meddy, Paul Sutton and 6 others like this.
  11. Mailman
    That’s some beautiful work there Jim! I have never seen that technique for bleeding brakes, it seems remarkably simple and effective. Nicely done sir! ;)
    Gator xs2, gggGary, Jim and 1 other person like this.
  12. Jim
    Thanks Bob. Yeah, it don't get much easier than that. Now we just need to talk Gary into doing a "how to" thread.:rolleyes::whistle:
    Mailman, robinc and gggGary like this.
  13. gggGary
    Nice pics and write up Jim!
    Would like to clarify my method a bit. Put piston into caliper just enough to engage it with the seal. Now hold caliper with line port upward and slowly pour in brake fluid. (next time I will use an animal syringe to make this quick clean and painless). when it's full install line and banjo. then with caliper held so port is at top, squeeze in the piston. this should get nearly ALL the air out, first try. Go ahead drain your brake and try it again my way. :laugh: :laughing:
    I do have a caliper laying on the bench.......
    Oh nice custom work on the MC cover! :bow:Jim:bow2:
    :cheers:
    Meddy, Mailman, TwoManyXS1Bs and 2 others like this.
  14. Jim
    Yer a funny guy.....:lmao:
    We'll just call this the MG method... Modified Gary method. ;)
  15. Jim
    Forgot... Paul was askin' about the VHT paint. I did spill a little brake fluid on it this time Paul. Didn't seem to bother it. 'Course I kept a wet soapy rag nearby to wipe it down pretty quick.... but it held up good against the brake fluid.
  16. Jim
    Decals from Diablo Cycle.
    These decals showed up today. I think they were about ten bucks shipped....
    Shout out to Robin for pointing me at these.:)
    Now I gotta go buy some red paint for the kill switch...
    KC 120, TwoManyXS1Bs, 59Tebo and 3 others like this.
  17. robinc
    I like the Testors Flat Red 1150-RM11501 ;)
    TwoManyXS1Bs, 59Tebo, Mailman and 2 others like this.
  18. Jim
    I've had a few inquiries as to the (lack of) progress on the SG. Guess I better do some 'splainin....
    I've had arthritis in my feet for some time now. Usually a day of relaxing here and there will be enough to keep it under control... until now. I finally bit the bullet and went to a specialist. He's put me on a steroid regimen... with cortisone shots to follow. Looks like I'll be off my feet for a few more weeks. Gettin' old ain't for the faint of heart.... but it does beat the alternative. ;)
  19. gggGary
    :doh:
    Tough old guy is redundant, there ain't no other kind.
    Gotta say I wuz wondering also.
    Hope you get to ride it a few times afore winter shuts you down.
    TwoManyXS1Bs, MaxPete and Jim like this.
  20. Mailman
    I hope the treatments work well and quickly for you Jim. Arthritis is a bitch! Feel better soon buddy!
    Jim and gggGary like this.
Share This Page
