1. Dismiss Notice
    Dismiss Notice
Jim's 1980 SG Miss September
Discussion in 'The Garage' started by Jim, Sep 26, 2017.
  1. Jim
    Thanks Ozboy. That's one of the HD coils I've been looking at.
    Damn... there's a lot more options out there than I imagined.
    MaxPete and Ozboy like this.
  2. Jim
    I've got about 225-250 miles on her now. You can't tell it from the speedo... which works whenever it feels like it. I've got 3 or 4 down in the basement... so one of these days I'll clean one up and replace it. For now I'm just using my phone.
    So anyway.....I went ahead and looked everything over. One of the exhaust valves had loosened up a thou or two. Readjusted. The cam chain loosened up a lot.... like 3-4MM. Readjusted. Everything else is just where I want it. Oil still looks brand new... no sparkles, so I'll prolly go to 500 mi. before I change it. Still debating on the coil and fwd. pegs.
    On Bob's recommendation, I ordered the Givi A-603 Windshield from Revzilla last week. It arrived today... so I installed it. Rode behind it for about an hour and it's pretty much how Bob described it in his Givi Review. I'm more than happy with it.
    Decided it was time for a good wash and some photo's....
  3. Mailman
    Very nice! Bike looks great, I’m happy to hear you’ve been getting some rides in!
    MrBultaco, Machine and Jim like this.
  4. TwoManyXS1Bs
    Jim, your bike looks great, like brand new.
    Great restoration job.
    I'd love to take a stethoscope reading from your front 2 guide bolts, and compare with others...
  5. Jim
    Thanks Steve. Yeah it'd be interesting to find out if the frankenguide is any quieter.
    Mailman, MaxPete and TwoManyXS1Bs like this.
  6. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    :popcorn::popcorn::popcorn:
    Jim likes this.
  7. gggGary
    Very Sexy Jim! Um the bike that is.
    Jim, Mailman and Machine like this.
  8. 5twins
    19,233
    10,434
    813
    It appears you haven't changed the spark plug caps from stock? I'd be doing that like right now, lol. The originals can and do go bad. Their resistance begins to climb and eventually that starts choking off the spark. Maybe that's happening with yours when they get hot? I'd try new caps before a new coil, maybe it will fix your issue.
    I'm just starting in on the process of adapting some Honda MP08 coils for me and my buddy. Reasons are as mentioned - cost, durability, and the ability to change plug wires. Neither of us seem to be having any issues with our current coils, we just want to try these. Once done, I will report on their mounting and function.
    MaxPete, mrtwowheel and Mailman like this.
  9. Jim
    The sputtering was only when the bike wasn't charging (I believe)... hot or cold didn't matter. And hasn't happened since changing the reg/rec. My experience rebuilding rotors has made one thing very apparent... the insulation on the copper wire is past it's lifespan. That's why the rotors are breaking down. Coils are built the same way; insulated copper wire wrapped around an iron core... and the same 40 yrs old. Although it's working just fine right now, I'm not trusting it for the reasons mentioned. As soon as my wishy washy mind decides which coil to use, it'll get replaced... along with the caps. They'll be just fine 'till then. ;)
    MaxPete likes this.
  10. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,285
    3,133
    313
    U.S.A.
    Here's how I did mine. Crazy drilling, but I was in a git 'er done mood. Works fine. The metal strip is hardware store standard stock that comes in about 3' lengths. Between the front coil mount and the frame is a washer the same thickness as the metal strip. I ground away just a small amount of a gusset to clear the bottom tower. Purplezinger, who used this coil first, had a more complicated way of mounting it.
  11. 5twins
    19,233
    10,434
    813
    I plan on mounting the new coil like the original - plug wires exiting out the rear and in a horizontal plane. It will require angle mounting brackets to flip it that 90°, but that's fine. I would have to make some sort of mount adapters anyway because of the MP08's smaller size.
    MaxPete likes this.
  12. Jim
    Before.....
    After....
    59Tebo, Wordman, Meddy and 7 others like this.
  13. madmax-im
    madmax-im Yamaha...Go your own way... XS650.com Supporter Top Contributor
    Awesome Jim..just a stunning bike...well done sir! :cheers:
    MaxPete and Jim like this.
  14. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    A few subtle differences.
    :cheers:Well done.:bow:
  15. Machine
    Machine Race the wind Top Contributor
    B0DD0B85-68F6-406A-926B-521A39025751.gif Like your style Jim ! You went for the gold ribbon and won !
    Your XS is so Hot !
    TwoManyXS1Bs, MaxPete and Jim like this.
  16. Mailman
    Yes indeed! Quite the transformation! Beautiful bike!
    MaxPete, GLJ and Jim like this.
  17. nighthog
    nighthog Lifelong member of the Easily Led Club
    I hope you're proud. You should be!
  18. MrBultaco
    MrBultaco it ran before being parked Top Contributor
    761
    2,340
    243
    Colorado
    Great job Jim...what a name for a new thread. Before and after. I bet there are many before and after pics.
  19. Jim
    Great idea!! Do it. :D
    TwoManyXS1Bs, MaxPete and gggGary like this.
  20. GLJ
    Great name for a new thread.
Share This Page
