I guess my memory failed me, I did not remember that spacer in there when I had my fork springs out. I had better re think this.
Sorry for the false start there Jim.
Yeah, it does Pete.It is an ‘81 Special fork - so I think it has the adjuster cap.
No worries Bob. When you get it sorted, we can go from there.Sorry for the false start there Jim.
The whole point of adding the 1" spacer is to fix the usually-too-soft stock springs and save the cost of buying expensive aftermarket replacements. Pete and Bob, you guys will want to check your springs to make sure they haven't been replaced. If they have been, you won't need to add the extra spacer. Pull them out and measure the free length. Here's some specs .....
I don't know what aftermarket springs measure but I do know they are a little bit longer.
Even though the '77 forks differ internally from the '78 and later ones, all the parts can be swapped around. Personally, I like the '77 forks. I think they were made a little bit better. The changes introduced on the '78 and later forks appear to be mostly cost cutting measures. The only real improvement I see in them is that they added little top out springs. But, you can swap those into your '77 forks if you like .....
The '77 fork tubes differ as well. You can pull the bushing and it's associated parts out of the bottoms. On the '78 and later tubes, they are crimped in place .....
I actually put together what I call a "hybrid" set of forks using what I felt were the best parts from the 2 types. I used '77 tubes and damper rods (Minton modded, of course), '78-on adjustable top caps, springs, and top out springs. They worked quite well but were a little soft. This was before I worked out the additional 1" spacer thing. I may try them again this season with the spacer. Assembled, they came out about 10mm shorter than a normal set, due to the taller '77 damper rod head and the added top out washer. But, that's not a bad thing. We routinely raise the fork tubes slightly in the trees (1/4" to 1/2") to lower the front end a little. These "hybrid" forks just do it internally. This is an old road racer's trick. Lowering the forks shifts the weight bias onto the front wheel a little more. This more firmly "plants" the front wheel and is supposed to improve steering feel and handling.
Fork Mods Continued...
While discussing the Minton fork mod, 5twins suggested adding a 1" spacer to the springs to compensate for spring sag. I've read several old road tests and such... and thinking back to personal riding experience, I decided to go that way.
Heh... yuse' guys didn't think I'd just hack off a piece of metal and stuff it in the fork... did ya? Nah... I tend to overkill stuff Besides, what's the use of havin' toys if ya don't drag 'em out and play with 'em?
I took some 6061 stock and made these....
Did I get carried away? Yup, I'd say so. Did I have fun doin' it? Absolutely
Hi Pete,All of my tapes, except the really old ones are metrics....
That it will Bob. I'm sittin' here lookin' at the bench I took it off of and wondering do I clean it or just throw it away... it's that bad.Keeps your garage clean!
Handy ain't they?I have one just like that.
Handy ain't they?
I look at it this way to........ if someone wants them there going to pay whatever the price.
Nice little pieces Jim and like Bob said PVC would have been my choice to as I don't have a lathe.........maybe would have just used some steel I had lying around.
