Endee
Hi all,
Just purchased a 79 special last night. I've wanted one of these for years and finally found ine for a good price.
It runs well enough but the carbs not set correctly. I'm pretty sure it's idling high, but I don't have a tach to check actual numbers. There is also a big flat spot right off of idle. Seems to pull fine on the rest of the circuit. I haven't pulled the carbs yet so I'm not sure what anything is set at.
The front brake is also weak. I've never done brake work before so I don't know what to do there or if that is common with these bikes. It doesn't pulse or squeak or stick. I will squeeze the lever all the way back and there isn't much stopping power the the front brake.
