KentMoney
I'm using a key switch I got from Kragen's for like $8. All the ones I found made especially for motorcycles were hella expensive, so I went with this. However, the build is sub-par and I am im the market for a new one. The face comes loose on it and its just a little janky, but its doing the job so far.
it technically a 4 prong switch. There is the off position when its vertical, if I turn the key to the left it turns on all the lights without the ignition (auxillary), one turn to the right is lights and ignition, and if you twist it further to the right it is a spring loaded (momentary, like a car) to turn the e-starter. no separate starter button, just the momentary key turn to turn the e-starter.
