Hi again Guys
I got the bike up and running again, after installing a new float needle. I started to rev the bike in the garage and was just about to take the bike for a ride, when I noticed that that my bike sounded just fantastic...the inside of the exhaust was on the floor...unintentional straight pipe...yippy!
Took the bike for a run...and it was just awsome...sounded great, accelerated and was very responsive...but one problem...gas leaking from the bottom of the float bowls...from the nipples. This is a 1981 HS with BS34 carbs, pod filters and 2-1 exhaust. I have tubes attached to the nipples and bends them upwards in order to "catch" the gas insted of pooring to the ground. Has anyone had similar problems or think they know what would cause the leak? It leaks pretty bad.
Another thing I noticed was a hissing sound from the gas cap...and a swoosh sound when I open the cap. Could this be related to the gas leak? I have installed a new gas cap seal. My gas tank has two petcocks, but I really don't think they are vaccum operated. I will try running with the cap not fully closed to see what happens, thanks to an older post that I just found...just not comfortable running with a gas leak
As always...truly appreciate your feedback
