jgmillican
XS650 New Member
I have a 75 XS650B. It's been in the shed for 15 yrs. Got it out a couple weeks ago and started to tinker with it. With a fresh battery installed, I pulled the plugs and checked for fire. Much to my surprise, both plugs were firing. I shot a little starting fluid in the carbs, and it fired up. I pulled both carbs off for a good cleaning, not to bad, just a little varnish. Shot B-12 through all jets, ports, and everything was open and looking good. When I put them back on it would crank up, but the left cylinder is not pulling gas in. I can place a couple fingers over the throat opening and the left cylinder will start hitting. When I remove them it goes back to running on the right cylinder. Any ideas?
