I warn you now I'm as grumpy as hell ,like a bear with toothache. I'm on a diet and can think of nothing but food at the moment.
Ok I have fitted my crankshaft into the upper casing several times without problem .
Today I decide to finally close the cases so I removed the crank and fitted the cam chain. (removed intact by PO ).
Now I cannot get the damn *&%$3"* crank main bearings to locate properly Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
I get 3x seated but not the forth.... then I get another 3x seated but not a different 4th bearing.
Whats the secret to getting these damn things seated properly before I take a 4 lb lump hammer to the crank.
To add to the problem its not just a case of rotating the 4x bearings to locate them onto their respective locating lugs but you also have to slide 3x of the bearing outer races back and forth on the crank at the same time .
I need carbs!.....
I need carbs!.....
