yerbluez
HI all,
I am a long time reader, a new member and first time poster. I've owned a 1972 XS 650 for about 3 years. It's an awesome bike, I really love the looks and feel to it. It's pretty much stock, an old survivor in a way. Haven't really had to do much to it in the last 3 years except change the oil and tires.
Anyhow I've finally gotten around to two things, the removal and lubing of clutch cable (which had been working fine) and addressing a leak in the left hand engine cover. I've been reading over these forums quite a bit over the last two weeks, it has been a great resource. But nevertheless, after reading so much I cannot figure out what to do now.
Here is my situation. I replaced the clutch pushrod seal that was leaking, and replaced it as suggested through many of the older posts on this forum. I installed the long push rod off mikes xs, with the two ball bearings still in position as far as I can tell. I lubed and replaced the clutch cable, worm drive etc, and put everything back together. Now the problem I am having, is that no matter how I adjust the the clutch at the lever or at the engine case, the lever is still very difficult to pull, and will no longer allow me to actually control how the clutch engages. In other words, I can pull the clutch lever in, put it in 1st, or 2nd or whatever, and without letting the lever back out at all, the bike goes into gear. I can still find neutral (with difficulty), but basically it seems I have messed up the actual function of the clutch cable and lever. It shifted fine before I did this work, I had only removed it because it needed to be lubed as it was already kind of stiff.
Any ideas?? i've been wracking my brains over this and it's getting irritating as I was hoping my first major project on the bike would make it function better, not worse... Alas, it's an old bike and I have lot to learn.
Thanks in advance, and happy July 4th to you all.
P.S. - here are some shots of the bike for your viewing pleasure.
