Sold / Found / Inactive - Looking for 74/75 speedometer/tachometer
cmarts
Saskatoon, Canada
Looking for speedometer/tachometer. Just need case and front glass piece so a broken instrument that is still round will do.
heads up
74/75 and 76/77 Speedos are different and the mounting and brackets are as well........Glass may interchange but the cases wont due to different cluster/Bracket set ups.
74/75
76/77
76.................................................77
76 Speedo Case........................77 Speedo case................80/83 cases changed color
All gauges from 76-83 cases will interchange with the 76-83 Cups
heads up
74/75
View attachment 118497 View attachment 118498 View attachment 118499
76/77
View attachment 118501 View attachment 118502
View attachment 118503 View attachment 118504 View attachment 118505
thanks for the info
heads up
74/75
76/77
So if I want to put my 74/75 speedometer internals in a different case, it will only fit in a 74/75 speedometer? I just need a new housing and cup for my speedometer which looks like it got run over.
Be more specific on what year you have and to make sure a pic will help. I had a special with a bracket made up to accommodate the 74/75 gauge cluster.
The instrument is from 1974 specifically. I am also getting a custom bracket cut out for me. I just need a round case so my speedometer will fit in the new mount correctly as the old one has been crushed. The internals work and I have already taken the speedo apart. I just need a new case to fit the parts into.
All i can say is the 74/75 Instruments housing is different to the 76-83 Instrument housings. The Gauge and cup and bracket set up is completely different to the 76-83 Gauge, cup and brackets...........they do not interchange............i have seen the instrument from 74/75 steel housing cleaned and polished without cups mounted to a bike but that was a home made set up
If you are making up something some thing specifically of your own then i have no idea if what you are doing is going to work...............As i said, and asked some pics, may have helped me give a better answer...............
Maybe when you get it worked out you can let us know what was done and how it worked out.........
Maybe i have just confused things and you should just go ahead and try. If some one has broken clusters i'm sure they will sell to you cheap or ..........
Is this what you are needing? Its held on with two small acorn nuts.
Does anyone know where I can get repro or new 75 speedo face plate the plastic park where the mph is printed
Mine was cracked but last night it broke into pieces
75 Is a one year only Face plate..........The changed the Trip meter and the Odometer meter around...........
Caution; . 74 Face plate Trip and odometer is the same as the 76, although some 74's will be sold as 75's
Go back and look to the pics on post #2
74TXA..........................................75XSB
And for a completely different question could I just swap out to a newer speedo so getting new trip meters are easier to come by?)and still use the 75 bracket ?
