1. Dismiss Notice
    Dismiss Notice
Looking for a ignition coil
Discussion in 'The Garage' started by RustiePyles, Jan 21, 2021.
  1. Jan_P
    Jan_P XS650 Junkie Top Contributor
    941
    1,274
    143
    Sweden
    Yes Sir
    # 37
    Nice piece but $ 40 + freight
    Mr 5 T perhaps has a drawing ..sketch someone closer will hammer out it for you
    Mr Pyles needs to break in ---test drive his new vise I would assume.
    That is something good to have even if a hacksaw also can do it. This time
    Get yourself a $10 HF 4.5" grinder
  2. jetmechmarty
    jetmechmarty What should I put here? XS650.com Supporter Top Contributor
    I don’t want to hijack this thread, but I have a 60 gal compressor and quite a few air tools. At issue is no electricity and too little space in my garage. I’m reluctant to spend money on a house I don’t intend to keep once I retire. My family and my wife’s family are far from here. So, that’s my story. Back to the regularly scheduled program.
    PeterD, thuban and Team Junk like this.
  3. jetmechmarty
    I got this from Joker Machine. They responded immediately. They couldn't tell me what coil it was designed for as the designer has passed away. If the measurements are in millimeters I'm pretty sure it's correct for a Accel 140403. Dyna is listed as 102 mm.
  4. Jan_P
    941
    1,274
    143
    Sweden
    Maybe I was wrong again
    Mr 5 T s fastener of sheet metal ..is much simpler to manufacture and the
    joker Machine drawing looks monumentally overdimensioned
    Unless there is a need for cooling heat transfer of the coil I remember Boyer Bransden have that
    https://www.baxtercycle.com/product/boyer-bransden-heatsink-for-dual-lead-coil-uk-made/
    note the brass heat transferring 2 parts
    So it can depend on what coil . . If it needs tight fit and a bushing in the Mounting holes
    the one in post # 27 have rather large exit post
    Can transfer heat that way ..
    Also the one on the picture is different from the one on the drawing
    Hacksawing out the one in the drawing in steel might be to much.
  5. 5twins
    21,755
    15,072
    813
    Yes, I don't think you need a coil mount that heavy. As I mentioned, I make mine out of like 16 ga. sheet metal and they've held up fine for many, many years. A coil isn't that heavy.
    jetmechmarty likes this.
Share This Page
