1. Dismiss Notice
    Dismiss Notice
Lucille pulls another one on me....
Discussion in 'The Garage' started by MaxPete, Jul 30, 2018.
Tags:
  1. MaxPete
    MaxPete Lucille, Betty, Demi & Gretel: I ask, THEY decide. XS650.com Supporter Top Contributor
    That sounds reasonable to me Paul.
    P
    Paul Sutton likes this.
  2. Paul Sutton
    Paul Sutton Still Looking Good Top Contributor
    Since we all appreciate the Yamaha specifications and guidelines you may be interested to know they recommend the oil is changed every 2000 miles - wow!
  3. 5twins
    20,449
    12,708
    813
    But we know better now, don't we, lol. Cam chain adjustment was also speced at about 4K intervals. That's too long. I check mine at every oil change, so about every thousand miles.
    And speaking of maintenance stuff, Pete, you might want to check the valves a few times in the first thousand miles too. Those new adjuster screws sometimes do some "bedding in".
    MaxPete, robinc and Paul Sutton like this.
  4. MaxPete
    Yup - I’ll change the oil at about 200 miles and then again before I leave for the VYR event. If anything is coming out in oil, it’s likely there now.
    The valves and timing chain - yup - and do it pretty frequently too. It’s a minor task.
    Pete
    YamadudeXS650C and robinc like this.
  5. Paul Sutton
    MaxPete, have you read the "User's Guide" for your bike? It has some useful comments regarding rpm limits when breaking in. If you do not have access then I will add a link.
    Edit: Should say "Owner's Manual".
    MaxPete likes this.
  6. MaxPete
    Oh boy - that would be super!
    Thanks very much!
    P
  7. Paul Sutton
    The "Owner's Manual for the TX650 contains information on Pages 22 - 23 regarding rpm limits during breaking-in. Here is the link to the xscafedotcom:
    https://thexscafedotcom.files.wordpress.com/2014/11/tx650-owners-manual.pdf
    I realize you don't have the TX but the information is the same in my HS Supplement so will apply to Lucille also. They also state the first oil change at 250 miles but I believe that is too long. From general reading I find recommendations from 50 miles upwards with different rational offered.
    After my rebore I changed at 150 miles with maximum of 3000 rpm being used and it really needed it. The oil was full of extremely fine metal suspension as expected. I then changed again after another 700 miles with a maximum of 4000 rpm being used and the oil was very clean. Changed after another 850 miles and at this point the engine started to run very nicely up and down the rpm range from 1200 to 5500. So it has taken approximately 2000 miles for the engine to start feeling nice and smooth. I am yet to go beyond 5500rpm but will get there soon.
  8. MaxPete
    Great info - that’s is pretty much what I had planned, but confirmation is great to have.
    Thanks!
    Pete
    YamadudeXS650C likes this.
  9. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    Off topic...........came across this RD250C,400C, 600C Gauge center console
  10. Superjet
    Superjet XS650 Guru Top Contributor
    Page 5 of the manual states: "high performance engine" and it is a hemi!!! Lol i like it!!!
    MaxPete and robinc like this.
  11. Paul Sutton
    One of the XS manuals states the top speed as 114+ mph. Anyone done that?
    MaxPete and YamadudeXS650C like this.
  12. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    We'll need a video of that.:)
    MaxPete likes this.
  13. YamadudeXS650C
  14. grizld1
    grizld1 Grumpy old man Top Contributor
    115 is the theoretical top speed at redline (7500 rpm) in 5th gear for Standard models, not the speed you can expect from the stock machine. With 17/32 sprockets I've had my D model up to an indicated 118 mph briefly with no alarming behavior, and it was still accelerating when I backed off the throttle at redline. But the motor and suspension are a long way from stock.
    MaxPete likes this.
  15. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,461
    3,797
    313
    U.S.A.
    One nice day I was cruising the Badlands with nothing nowhere and glanced down and noticed the speedo was buried. It only goes to 80 though...
    robinc, MaxPete and Mailman like this.
  16. MaxPete
    ...riding it off a cliff doesn’t count....
  17. MaxPete
    You need a Canadian speedo - they go to 140 MPH - but again, that would only apply if you rode the XS650 off a cliff....or were being towed by a Hayabusa.
    Mailman, robinc and Jim like this.
  18. MaxPete
    Well, my odo since the rebuild was up to about 225 miles this morning so I changed the oil again and tomorrow, I’ll retorque the head again.
    The oil came out nice and clean and the sump strainer looked virtually new. So, I cleaned it and plunked it back in. The side filter had a small amount of swarf in it so I simply tossed it (I’ve got a bunch of spares) and refilled the oil. I screwed in a new set of plugs (the old ones looked a tad rich but basically brownish) and then I went for a 50 miler and ahhhhh.....very nice.
  19. robinc
    robinc Member of the 'yellow meter gang' Top Contributor
    :umm:
    MaxPete likes this.
  20. MaxPete
    Hehehehehehe......
    robinc likes this.
Share This Page
