I'd be relieved, too....Wow am I EVER relieved this wasn't worse'
Don't forget to give 'em the guide seals.......and drop off the head as well for a valve job and a good cleaning.
...The LH cylinder is slightly more worn with a bit of cross hatching showing but there are also four distinct sets of vertical marks that are adjacent to the cylinder studs...
An interesting pattern. That, and the silvery appearance of those vertical marks (melted aluminum), makes me think that cylinder may have experienced overheating, imminent seisure. Hot spots at the studs due to longer heat path to the cooling fins. Could look for matching melt/score lines on the piston.
Is the delaminated front guide an OEM, or aftermarket?
Sure thing Pete. Will do when I get home this afternoon.
Although IIRC, they all have a channel, will confirm
... The piston....hard to say - it doesn't look bad but I'm going to ask Terry at the machine shop what he thinks...
... The failed guide has a channel-shaped cross-section while the one I just bought (which was billed as an authentic NOS part) is flat and has the black slipper material bonded to it...
Pete, that may be the older -00 front guide, usable only on XS1s, with a type "A" tensioner system. If so, I'd like to buy it from you. Some comparison/reference pics in these:
