After looking at Gary's diagram Bob, maybe it's off a little and the brown feeds the safety relay. Ohm it with your meter and see if that's the case?
Hi. What I have done in the past on Petrol pipe unions when I couldn’t stop them leaking is, find a small copper washer, inside dia the same as the hole in the pipe 3mm I guess and outside dia to fit inside the union. Anneal the washer, heat up to cherry red and quench in water, put said washer in between pipe and fitting, nip it up, no more e leak. Hope it helps.I’m a little concerned about cutting any length off of the existing line. Because the length puts the fitting right at the mounting point on the fork leg. It has to hit that at just the right spot because there is a rubber bushing that goes over the fittings and fastens to the leg.
ith the kill switch off the starter does not work. I went to the starter solenoid expecting to find a red/wight and a blue/white. What I found there was a solid brown and blue/white. What the hay, that shouldn't be. Wires should not change color/number in the middle of a run.Went to my other XS2 that I have the tank off of and look what I found.
At the coils the R/W changes to Brown.That's not cricket.Yamaha played fast and loose with wire colors. Makes a guy wonder what else they might have done. I wonder if Mailman's is same?
Mailman you may want to read through this thread it relates to the XS2s.
http://www.xs650.com/threads/xs2-wiring-diagram.53244/
Nice job on that coil mounting, Bob !
My simple brake line bender cost me a couple bucks back in the day:
That wiring diagram is a conclusion from the thread GLJ posted........A continuity test may help but my reservation is where the Red/Yellow and br wire run into the bullet connector at the coil. being joined will trow the test from the Safety relay..........????.
I don't understand what you mean when you said you just capped off that brown wire.
I'm really surprised you cut those wires, lol. My '78, like your '77, had 2 R/W wires coming out of the harness, one to power each coil. They are actually 2 leads "Y"d off the same wire in the harness, the wire is split into 2 wires. I utilized both for my Pamco install, running one to the new coil and the other to the Pamco red power wire. I added bullet connectors to the Pamco wires so everything just plugged into the original harness connectors. My new coil, like yours, had flat spade connections on it. I made short jumper wires with a flat spade on one end, bullet on the other. Everything is "plug and play" so none of the original wires from the harness were cut or altered.
What I did was simply cut the two wires right here , before the connection, then separated the two wires and ran the red/ white wire to the coil. The brown wire was simply taped off and tucked outa the way for the time being. I had a feeling at the time I was going to have to come back and do something with it. I’m not in the garage today. But I intend to redo the wiring. I need to return power to that brown wire for the safety relay and I also want to include a 7.5 amp inline fuse to the power supply to the coil , as per Pamco Pete’s recommendation.
Photo shows where I cut the wires.
Just one more option for front brake line.
I have the one off my parts bike, while not a 10 point show condition I think it is very usable. If for nothing else to prove the problem is in your steel line.
View attachment 135373 View attachment 135374
The roughness in the lower picture is not as bad as it looks!
Say the word and it could be in the mail in the morning. And I do know where you live!
Ken in NY
.Mailman, now that you have cut those 2 wires it would be a good time to continuity test these circuits..........Doing the test below i can finish with confidence the wiring drawing in that area.
Test the Br wire you cut at the points and at the safety relay. If it is infinity then it should prove the power is going to the safety relay from the R/W to the Br where it joins at the coil Bullet connector.
Also test the R/W on down side of the kill switch and the Br wire at the Safety relay. If infinity the the Br off the relay is joined to the R/W before the Coils and the Br runs along side the R/W the as per my loom..........If full resistance then the power is coming back on the Br wire from where it joins the R/W at the coils.
This is my nomination for the Annual XS650.com Generosity Award.Just one more option for front brake line.
Ken in NY
.I’d be happy to run that test for you.
