Well, just a quick easy check you have not yet mentioned.
While it is running can you check the lft cyl timing with a timing light ?
When you checked compression did you have the valve covers off?
You might want to remove the cable going to the decompressor and see if that makes a difference.
When I first started my engine mine acted a lot like that. After getting carbs closer in balance that seemed to calm down.When the timing light is on the left cylinder wire. The spark is MOSTLY steady, sometimes however it’s jumping all over, firing way before TDC. When I see this random flashes, the bike always misses.
That is true but if you were missing one of magnets in the rotor it would fire every 720°.You're using a waste spark iggy system (both cyl. every 360°). Swap the plug leads. If there's no change, you've eliminated ignition as source of problem.
If I understand dual output coils when 1 fires the other fires. I'm going to have to ponder on this for awhile.Yep. And swapping leads would answer that. Magnet is correct for right cylinder. If both magnets are there, it will continue on right cylinder with leads swapped. If 1 magnet is missing, it won't run at all with 'em swapped. Hence.... did the problem change... or not.
Correct. on compression stroke on one cyl.... and at valve overlap on the other.... every 360°. If one magnet was missing and it was firing every 720°, only the cyl. coming up on compression would start a fire.If I understand dual output coils when 1 fires the other fires. I'm going to have to ponder on this for awhile.
Was that at idle?GLJ, I did put a mark on my ignition rotor as you suggested and it did just what you said it should, the timing light lit the mark up at exactly 180 degrees from each other.
Tuning is fun ! trouble shooting ? for me not so much.Tuning and trouble shooting never have been my strong suit. I can be logical and work through things, but tuning is almost an art.
Was that at idle?
Swap plug wire so you can rule that out.Kinda sorta, maybe 1500 rpm.
So, this thread has been going on for so long, I don't even remember - you installed a Pamco? If so, it's dual output coil would (should) fire both plugs at the same time, every time. The only thing that could cause a poor or bad spark on one side would be that side's plug, plug cap, or plug wire. So yes, switch the wires side to side to see if the bad running follows. If it does then you'll need to check (test) the plug cap, the cap's connection to the plug wire, and the plug wire's connection to the coil.
