Chasing an oil leak
So earlier I commented that this engine was just naturally messy. I need to amend that. I was blaming oil vapor coming out of my vent tubes for making the underside of my bike and my back wheel an oily mess. The starter gear case was all oily too, so I made another assumption that my gasket was leaking. Before I took my 75 mile ride yesterday, I had the left cover off and cleaned everything in there, and cleaned the underside of my frame and rear wheel. By the time I got home yesterday and pulled the bike in my garage, there was a small drip coming from under the left side cover. Hmmm......I was thinking about this last night and there are a lot of potential suspects under that cover, nothing to do but dig in.
First glance , I can see the shift shaft guard is covered in oil and oil has been slung around under the side cover.
It was dripping from the starter gear case, the shift shaft guard, the drive sprocket. Ah well hell....I’m just gonna pull everything off and take a good look.
I pulled the chain , sprocket and shifter guard off and found what I was looking for. The back side of the sprocket was wet with oil, the sprocket was slinging oil all over and the chain was carrying it to the rear of the bike and throwing oil all over my rear wheel and spokes.
This is a little puzzling because the sprocket nut was tight and I had put a layer of Hylomar on the back of the sprocket where it tightens against the drive shaft.
I am going to clean everything up and try it again , this time maybe a little Yamabond on the backside of the sprocket?
At least it doesn’t look like I’ll have to replace any seals.
We shall see.
Bob
