1. Dismiss Notice
    Dismiss Notice
Mailman’s XS2 a full on restoration
Discussion in 'The Garage' started by Mailman, Mar 1, 2018.
  1. yamahama
    yamahama XS650 Enthusiast
    I was looking at an original seat full of frikin dust/dirt over the white lettering...But, now, looking for a forum thread to ask if a set of 1972 LS 2 ft. and rear turn signals will cross over onto a '72 XS650. Sort of looks like it.
    gggGary and Jim like this.
  2. 2XSive
    2XSive At least one screw loose behind the handle bars XS650.com Supporter Top Contributor
    301
    1,194
    143
    Michigan
    I just ordered some 6mm double lip seals plus the seals Jim suggested (24mm vs standard 25mm inner diameter). Gonna nip these leaking seals one way or another.
  3. Mailman
    I’ll be interested to see your results!
    thuban, gggGary, Jim and 1 other person like this.
  4. 5twins
    19,198
    10,366
    813
    Mailman, I noticed looking at your seal pics in post #3297 that the seal in the 1st pic looks to be seated in on the cam a little more than the seal in the second pic. I think I can make out the seal number (size) in the 1st pic and it looks like it's a 5mm thick seal. Is the seal in the 2nd pic possibly a 6mm thick one? Nicely greased advance rod bushings by the way.
    YamadudeXS650C, Mailman and gggGary like this.
  5. Mailman
    I looked through all my reference photos and can’t tell for sure. I’ll try and take a peek and see if I can see it.
  6. Mailman
    The other day while I was working on my bike, I noticed one of my muffler clamps was loose, when I went to tighten it I realized the clamp was broken. I checked online and it is NLA from Yamaha, so I found a couple on Mikes XS.
    I ordered two, because the one on the other side had been damaged by battery acid, long before I got it. Today they arrived ,
    Off with the old......
    And on with the new!
    DDC96077-35F9-4FE8-99EA-C77621D9CBCB.jpeg 39EF392F-CA9F-47CD-8F9E-DFBE57B10BF2.jpeg
    It’s the details that count don’t you know. :cool:
    MaxPete, thuban, Paul Sutton and 4 others like this.
  7. cra-z1
    cra-z1 XS650 Junkie
    778
    835
    93
    Idaho
    Its funny about those clamps. When I first installed mine I decided that the brace spanning the clamp and the other bracket were not needed. After a while the clamps started to rotate and the only thing to stop that was to install that brace.
    GLJ, Jim and Mailman like this.
  8. 2XSive
    301
    1,194
    143
    Michigan
    Well, I think I finally resolved the leaking cam seal issue. I ordered two of of the 6mm wide seals (vs 7mm which is what Mike's ships) and thought I'd try the 6mm x 25mm ID seals first before giving the seals Jim mentioned (24mm ID) a try. I eliminated the paper gasket behind both housings, used just the rubber o-ring and aircraft sealer on the mating surfaces, and pressed the new seals in so they slightly protrude beyond the housing surface. You can see from the first "before" pic how the lip of the seal was right on the edge of the camshaft. The "after" pic shows that I have a good 1mm of the camshaft protruding beyond the new seal. Same now on both sides. Went for a good 20 mile ride (finally had a day over 50 degrees) and so far it's bone dry. Will report later if anything changes. Also polished the cam shaft a bit with a scotch pad before installing new seals. One thing I noticed is that I could hand press these new seals in, so just a thin coating of aircraft gasket sealer was applied to the mating surfaces prior to install. I then let it dry good before taking it for a run. So far so good! Inkedcam seal old_LI.jpg Inkedcam seal 1_LI.jpg Inkednew install_LI.jpg
    thuban, Paul Sutton, gggGary and 3 others like this.
  9. Mailman
    Terrific! I hope this does the trick for you. Thanks for the update, I’ll have to give mine another look soon! :thumbsup:
    thuban, gggGary and Jim like this.
  10. 5twins
    19,198
    10,366
    813
    ..... and the seals Yamaha now sells should be even better because they're only 5mm thick.
  11. Mailman
    Would you order those from Partzilla?
  12. Jim
    Here's what's confounding me about this whole sealing issue... These are simple dual lip garlock seals. Being a garlock means there's a spring on the inside forcing the sealing lip against the shaft to form an oil tight seal. There's two lips, the sealing lip I just mentioned and the dust lip. What we're talking about here is using thinner seals... or doing away with the gasket.... or whatever else we're doing... all to bring the dust lip further in on the cam. The thing is.. the dust lip isn't what keeps the oil in... that's the sealing lips job.
    The proof's in the puddin' as they say... and I hope your seal stays dry Larry... I'm just at a loss to understand why giving the dust lip more purchase is stopping the oil. :umm:
    MaxPete, Team Junk, thuban and 4 others like this.
  13. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    It may have more to do with giving the seal a new area to ride on. Just a thought. We used to put Speede-Sleves on harmonic balancers so the seal would have a new surface to seal on. Worked well.
    Paul Sutton, thuban, gggGary and 3 others like this.
  14. Jim
    Could very well be it Greg. In which case... might be able to use an exacto knife and trim the inside of an existing seal so it seats further in without hitting the cam bearings.
  15. GLJ
    Only thing that makes sense to me. Then again what do I know.
  16. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
  17. 2XSive
    301
    1,194
    143
    Michigan
    Though the dust lip isn't meant to seal in oil, I gotta believe there is some element of additional oil sealing going on by having it ride solidly on the camshaft vs. Right on the edge. Perhaps by giving that dust lip a firmer/even surface to ride on, the actual spring in the seal can do it's job better. Just a thought.
  18. 5twins
    19,198
    10,366
    813
    The 5mm thick cam seal can be had from any Yamaha dealer, it's what they sell now. This is the seal they originally used on the 650 for the first few years of production. Then for some reason, they switched to a 6mm thick seal. But now they've gone back to using that old original 5mm thick seal. At the top of the list .....
    [​IMG]
    Paul Sutton, 2XSive and Mailman like this.
  19. yamahama
    I'm turning pg 9 now and my eyes keep getting wider...I went the Evapo-Rust route but need to do more. Lucky my gauge faces were not in the sun but had to take fine steel wool to see if it removed the rust...yes, easily. OK, on to pg 10 of Mailman's resto... P5200357.JPG P5200355.JPG
    Mailman likes this.
  20. 5twins
    19,198
    10,366
    813
    Your gauges are OK, it says so on the back, lol.
Share This Page
