Have you tried to source the pistons yet Bob?
Cost?
Cost?
Well, relatively speaking... that's not too bad. Was gonna suggest a brazing rod to fill the pits in....They do, approximately $20 each if memory serves me.
Interesting - I’ve never seen a disc mounted like that.
Instead of silicone on those little rubber pockets I wonder if red rubber grease would be better....
Pete
Ya made me chuckle Bob. Here's how we do it on airplanes. First you watch somebody that knows how to do it, do it.... then they watch you do it, and correct you as you go. Then we let you do it by yourself. That way, we don't have airplanes with hundreds of passenger crashing into school buildings with the attendant mayhem that accompanies said crash.....Thinking back over thirty years ago, I think I made a good decision to be a mailman instead of an aircraft mechanic!
Ya made me chuckle Bob. Don't sell yourself short. I woulda taken you on one of my crews anyday
“ When nothing goes right.......go left.”
So I actually started this job a couple days ago. I spent a lot of time cleaning the parts and then spent some quality time with my Dremel and wire wheels to remove the rust and corrosion. Finally wiping everything down and masking and painting them. That was a couple days ago and I had them hanging out in the hot Arizona sun to harden the paint.
I have my rebuild kit on hand , as well as new brake pads. I thought everything was in good shape and I was just about ready to proceed, then I realized that what I thought was just some stuck on crud, was actually rust pitting ( AGAIN) on my pistons. I even tried wet sanding them with 1500 grit paper, but I fear they must be replaced before I can continue. I can feel them catch on my fingernail, they would wear the seals and allow air into the system.
View attachment 117488 View attachment 117489
So here I am, stalled out again. I’m kinda making progress....in a sideways sort of way. Sigh....
MY WHEEL BEARINGS INSTALLATION
Kind of.....sort of......not really.
I had a brand new set of wheel bearings that I bought for my ‘77 and never installed. After doing a little checking to make sure that they would fit, I got organized and ready to install my bearings. This was my first time installing wheel bearings on a motorcycle and I wanted to be prepared. I watched videos and read how to articles and I felt ready. I have a new bearing driver set that until now have never found a use for, I was happy to see that they fit my wheel bearings exactly.
I cleaned the bearing pockets on the wheels and smeared some grease, both inside the pockets and on the sides of the bearings. Then tried tapping them in with the bearing driver. I was having difficulty with the bearings tilting and getting cock eyed in the hole. So I tried laying the bearing on top and using a small ball peen hammer and gently tapping around the outer edges of the bearings until it was going down straight.
Then once it was straight, I switched to the driver and drove the bearings home.
I was so focused on driving the bearings in straight, and happy with my successful installation. That’s when I saw this lying on my bench.
Yup! The spacer that was supposed to go inside the hub between the bearings. S.O.B. !!
Ok .....ok.....put it behind you, there’s still the rear wheel to do. Just keep your focus and remember the spacer this time. And I did, the bearings went in beautifully, the spacer was installed. But wait! WTH? The spacer should be snug in the center, but it’s rattling around!
I’m looking around everywhere trying to figure out what I did wrong, then I spotted it. I had the old bearings stacked on the back of my work bench and I realized that under some old caked on grease, there was a little top hat shaped bushing still stuck in the old bearing! Number 17 in the diagram.
So...there I am .....two for two! New bearings have been ordered and I feel properly humbled. I really had this internal debate whether or not to come clean about this little episode, but I kept thinking this is how people learn and perhaps my example will help someone else avoid the same mistakes.
View attachment 117857 Haha! You’re welcome air travelers!
Igg-nernt question here: Why new bearings? You can't get the "old" new ones out without damaging them?
I refer to such exercises as "practice". Do it, notice one of those pesky extra parts, take it back apart and do it again.
Like the time I had the bottom end of the engine back together and all torqued and noticed that "No, Dumbass, you CAN'T put that seal in after the cases are torqued down. See that little lip, Genius Boy?"
Or, more recently,
There are two kinds of mechanics out there: Them what HAVE done something like that, and them that will...
