....or maybe some shag carpet?
Wait....what did I miss? You did all that engine cleaning and polishing, and now you're going to cover all that work with paint?
If you had to put something over it, couldn't you clear coat? Or isn't there such a thing as a high-temp clear?
Is it just the top (half) of the case that's painted? Because the bottom of the case looks real shiny, and not yellowed at all... "The Basketcase" is so barnacle encrusted (corroded, from years of holding up a shed) I have to disassemble the engine and soda blast it just to make sure it's actually aluminum....
Hi Mailman: I have enjoyed following your journey!!! I do have a question though. After going through all the work on the upper end (and the rest of the bike) why have you decided not to break the cases and check the transmission and main bearings and do the final cleaning inside where all the action takes place? Just a question and not a criticism. Keep up the great work and I hope it turns out as good as you want it to. DavidSo today I replaced all the seals under my left side cover. I did comprehensive write ups in the Garage section so I won’t re write it all here but I wanted to include some cross references here.
http://www.xs650.com/threads/replacing-engine-seals-part-one-the-shifter-seal.52589/#post-556676
http://www.xs650.com/threads/replacing-engine-seals-part-2-clutch-push-rod-seal.52590/#post-556659
http://www.xs650.com/threads/engine...shaft-seal-driveshaft-seal.52591/#post-556675
The seals are all in! With the exception of the starter seal which I will install when I replace the starter.
Stick a fork in this job cause it’s DONE!
MAILMAN OUT !
. . . . . until the NEXT one!!! Bwaaahahahahahahaha!!!!!!!!Stick a fork in this job cause it’s DONE!
MAILMAN OUT !
Bob,......if that bushing for the kick starter comes out of the case easily? It would make it easier to replace the seal.
Bob,
a 3/6 or 1/4" punch works good even with the bushing in. Angle it across the bushing and work your way around it. It helps to take an exacto knife and cut the lip out first.
I don't think that kick shaft bushing comes out of the cover very easily, I'd just let it be. The kick seal pops out pretty easy though using that seal removal tool you have. With no shaft in the way, it easy to get the tool hooked under it. Just take care you don't go into it too deep or you'll gouge up the hole in the case.
Yes, I would try your clutch as is, as long as all the parts are OK. It's got some funky ones in it though, lol. There are rubber damper rings between the plates. Hopefully they're still good because I don't think you can get them anymore. Also, I'm pretty sure the friction plates differ. See those 2 in the middle of the stack in your pic, the ones with different colored edges? I think those are aluminum based, not steel based like the other frictions.
