Now how cool is all of that Bob. Once again the brotherhood of this place blows me away! Man.
Ain’t that the truth!
Glad I could helpThanks again Jim, for both the work you did and coaching you gave me on technique.
A "practiced hand" knows to use what works...I also received my piston ring pliers. I know you practiced hands probably don’t use them.....
Daylight?!! You mean your reflection?!! That thing is SHINY!!! If the motor from "The Basketcase" turns out anywhere near that (from being so roached, spending years holding up the side of a shed, I refer to it as "barnacle encrusted") I will be thrilled. Your bike is future calendar material! And the work it took, inspirational. I can't wait to see the whole, fully assembled. (I'm sure you can't either!)I’m beginning to see some daylight here
DAYLIGHT!!!!!
Your futures so bright you gotta wear shades! You could shave in that thing Bob! You must have wiped away all the sweat.
Unbelievable Bob. Beautiful work brother.
Hey Mailman How did that brush kit hold up after all the cleaning you did. Looks like a good kit and i can get them here Downunder but if they dont last i wont bother. Great tip on the blocks of wood.
Cheers!
I think you need to split the cases to replace those seals. I assume you are cleaning the outer surface before you do split them. If I remember those seals have a ridge around the circumference.
The brush kit works great, I highly recommend it. It all holds up well, I kinda messed up one brass brush by forcing it into too small of a hole, but other that that, the rest held up really well.
OK Bob, so now YOU'VE gotten to polishing the INSIDE of your cases. Remember what I said about these guys.........
Beautiful work buddy!
I doubt that the Rustoleum will be gasoline-resistant, Bob, unless you get the engine enamel. I think you would be better off with a can of automotive DupliColor gloss silver/aluminum.I bought some Rustoleum that says it’s gloss aluminum
