Hello ALL!
Most of the wireing is sorted out. Stock except for RS/Chrysler rec/reg, PAMCO w/ ATU ignition and the KZ 650 taillight. I wanted to use the KZ tail light relocate it further down and further back on the fender. This is due to the larger luggage rack which would have hid the stock tail light its stock location by the seat. The turn signals were re located on the rack. They were plug and play as was the ground wire and parking circuit for the tail light. I will probably cut the brake light wire on the 6 pin cupler and put a snap pin on it to plug it in the tail light.
Things left to do:
Torque up the head/top end and install the top motor mount.
Finnish the wiring.
Clean the carbs, wet float check/adjustment
Do valve adjustment/tune-up.
Buy bushings,washers for the shock mount studs. Lot of room on the stud due to the push bar being removed.
Get the engine running and final carb, ignition settings.
Deal with anything else that rears its ugly head.
I brought out a bar end mirror that I wanted to use and tried to put it in the handlebar. For some reason the wall of the tubing is VERY thick and I cant use it. I may change handlebars. Try to find some superbike bars.
So close and so far.
Things left to do:
Finnish the wiring.
