Bob Kelly III
Ranch Kid from way back,.... that got Old !
Hi all...
sense I decided to make a Cruse control/throttle lock I figured I might as well document it so others could get the idea on how to make one .
let me stress that this is not the only way to make a throttle lock/cruse control....
I think Most Honda's have the adjustments already in the throttle control / switch housing and simply need a knob so you can adjust it on the fly.
However My 82' XS650 has just a hole in the throttle housing and I didn't feel like making a threaded base for an adjustment screw with a knob on it, so I went with this strange arrangement.
years ago you could buy these type throttle locks at the bike shops all over the place but many of them were quite expensive....
so I decided to make my own..... like this.....
I scrounged through my scrap metal pile and found a 3/16" plate of aluminum from one of my Gyrocopter builds ages ago..... I drew a rough design of what I wanted it to look like on the metal and cut it out.....
i drilled the holes and then put 2 nails through the holes to temporarly assemble it. and get an idea on how it funtions...
and after mutable fittings on the throttle itself......
I then cut the nails and riveted the ends of the nails over so they couldn't fall out of the holes.
the 2 holes in thefront bracket are for pins to keep the thing from rotating when clamped down on the throttle.... turns out I only needed one.... made from a nail and riveted into the tight hole.
i then had to file down the pin a long way as my riviting made the pin swell quite a bit and it wouldn't fit into the hole I had drilled into the throttle bracket/switch housing..... but once it fit ok it was on to the next step. .... fitting....
with the unit unable to rotate I now needed a way to adjust the squeeze on the throttle...
sense the aluminum was too thin to drill through in the direction I needed to go through , I took my torch and heated the ends of the metal so I could easily twist the ends to a flat orientation in the direction needed.....
this will also give a bit more clearance away from the throttle hand so as not to be bumped.
now it was just drill a hole for a bolt to go through.....
and that's the completed unit so far..... I plan to add a knob to the bolt and attach the nut on the back of the bolt to the aluminum and then drill a tiny hole so I can put a safty wire through the bolt so the knob will not vibrate out when loose.....
this Whole idea is so you can take your hand off the throttle without the throttle snapping closed
which is necessary for people with carpal tunnel syndrome...or hands that go numb after a while on a bike ! being able to flex your throttle hand is a must for me as my hands go numb fairly fast when gripping the throttle.
I tightened the small bolt and nut at the bottom of the "Cruse control/throttle lock" and got it to hold the throttle in any position I wanted.... however I do want it where I can back it off if I want to
or snug it up while going down the road.... that's where the Knob will come in handy...
but for today that is all I have !
enjoy....
Bob............
enjoy....
Bob............
