1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Mannulus Mechanica (build thread)
Discussion in 'The Garage' started by RustiePyles, Oct 28, 2020.
Tags:
  1. RustiePyles
    RustiePyles Semper Fortis XS650.com Supporter Top Contributor
    Finally got back to working on the chopper. The the bike didn’t have any neck bearings in it when I got it so I’ve been rolling it around like that. Pretty tired of the front end folding up when I try to get it up on the lift. So I tore the front end off and put a set of All Balls tapered roller bearings in it and a new tension/jam nut. I put on the rotor flange cover I got from @Beags64 on the front wheel. I’ve got a buddy 3D printing some bushings for the gaiters.
    68007A3B-6DA7-4215-A3D3-B39BCEC66BCE.jpeg 201563D7-24E2-4604-8BFB-D68AC992CCCE.jpeg E7BF97BB-9FAF-453D-8D19-BB9BE3EF0477.jpeg 5D755C73-2C3E-4ACA-93D3-B2A1E6C31FC5.jpeg 5A783371-0C13-4D30-A357-B343158DB54C.jpeg
    jetmechmarty and Mailman like this.
  2. RustiePyles
    I also dropped the headlight down about 2”, not sure if I like it or not. Next time the forks come apart I’ll make a set of lowering spacers and lower them properly.
    778647E5-C6C8-4050-9907-920C44A82864.jpeg FEBAAD93-C507-4720-8DB0-D8B30FCFC41A.jpeg 22CAAB84-08F7-447A-AF9C-5E94573903D7.jpeg B76DF8C9-7913-481F-BABF-32484E6ED162.jpeg B09FE452-59BC-4211-A49D-6F393BA592F8.jpeg
  3. RustiePyles
  4. RustiePyles
    Since I hade the rotor off, I decided it was time to drill it. Covered it in layout fluid and laid it out with dividers and a V square. Had to get a little creative to get it jigged up in my tiny drill press. Used and old Craftsman 4 jaw lathe chuck, a set of 321 blocks and machinist jack.
    I used a large SS star knob to secure the chuck/rotor to the table so I could quickly tighten/loosen it.
    876B3948-2829-4B2D-82F8-2F7D2AE6EE63.jpeg E206AAD3-640F-4323-8A69-46F9256F8EB3.jpeg F0858383-E5D7-4A7F-972B-9C77FBA159B1.jpeg E6B7BECB-C518-48B4-B7A5-11E38BFAA747.jpeg C42D0E11-E6ED-4E9A-B805-E30DF94B74EE.jpeg
  5. BowlingSS
    BowlingSS XS650 Junkie XS650.com Supporter
    You are getting there. Keep it up.
    Adamc, RustiePyles and Jim like this.
  6. Mailman
    Great work, your bike is really shaping up!
    Adamc, RustiePyles, Jim and 1 other person like this.
  7. Jan_P
    Jan_P XS650 Guru Top Contributor
    1,038
    1,441
    163
    Sweden
    Just a thought as input ...Better now than after the chrome is on perhaps worth consider
    The upper exhaust perhaps close to the wallet ? in the back pocket of the driver
    And if a passenger seat in the future shall be an option ( perhaps next owner ) It wont hurt to test sit on it thinking in those terms.
    Personally I don't like back mudguard with nothing on them even if a passenger is not so common But sometimes it is good to have
    a backseat.
    I have even picked up unplanned lifters after Motorcycle Breakdowns / Bus not coming because of holiday / And people set off at the roadside after an argument in the car ( Lady of Course )
    RustiePyles and Adamc like this.
  8. Adamc
    Adamc XS650 MEDDLER XS650.com Supporter
    274
    777
    93
    Wales
    I will watch this one with interest!
    RustiePyles likes this.
  9. Adamc
    274
    777
    93
    Wales
  10. RustiePyles
    Stock XS650 Heritage Special wheels.
    Adamc likes this.
  11. RustiePyles
    @Jan_P my wallet isn't in any danger, thanks to old motorcycles its mostly empty anyway:lmao:. There 's going to be a heat shield there and both pipes will extend to the end of the frame. Not to worried about passengers, there is only one passenger I'm allowed to have and she has her own bike. If she REALLY wants to ride with me we can take the 80 XS650G. Choppers are supposed to be dangerous :bike: most everything on this bike is form over function. As for future owners, thats more their problem than mine :shrug: A P pad is easy enough to install at a later date. I'm also not sure if I'm sticking with that seat. I may make a cobra style seat.
    Raymond, Jan_P and Adamc like this.
  12. joebgd
    joebgd XS650 Junkie
    525
    266
    63
    NY
    How was it to drill the rotor. Was it any harder or softer.than expected?
    Adamc and RustiePyles like this.
  13. RustiePyles
    I got about 75% of my pilot holes drilled (3/16), I started with a new sharp nitride coated HSS bit. It’s still cutting like a champ, haven’t used a single drop of oil or coolant. Keep your RPMs low and quill feed pressure steady and firm.
    joebgd and Adamc like this.
  14. 5twins
    21,922
    15,470
    813
    There's really no need for the grease seal on the top steering bearing. The original tin dust cover is sufficient. You do want to use it on the bottom though, it really helps there. Put the original rubber one back on too.
    Adamc likes this.
  15. RustiePyles
    I need to order a dust cover, I only used the seal as a washer. I wanted something between the nut and the inner race.
    Jim and Adamc like this.
  16. Jim
    OEM's are still available at Partzilla, Partshark, etc.
    Paul Sutton and Adamc like this.
  17. RustiePyles
    Yeah I found it on Partzilla for $9. I'm not in any hurry, It'll go back together with the dust cover when it comes apart for paint. I just needed to get the front end stabilized for moving it around the shop and up and down on/off the lift table. I was afraid I was gonna wreck the stem/race seats moving it around with no bearings just clanking around in the neck. I might even turn a fancy SS or billet aluminum dust cover.
    Adamc and Jim like this.
  18. TJZ662
    TJZ662 XS650 Addict
    I’ve never had to braze anything in the field but man that inspired me to go try. It’s just a hose rack, no pressure or anything obviously. The build is definitely looking good though
  19. RustiePyles
    Thanks! For never having brazed that looks pretty good! Definitely looks like it'll hold.
    Adamc likes this.
  20. TJZ662
    TJZ662 XS650 Addict
    Oh yeah it should hold.. i think. I usually use silicon bronze over a tig bead to just get the appearance
Share This Page
