For Sale - MANX exhaust, misc oem electrical, headlamp, brake caliper, & more
turn left
Go Fast & Turn Left
San Francisco
parts for sale
SOLD
Flasher Cancel Unit 1.00 sold 5/3/12 Cafefill
62mm. id Pod Filters 8.00 sold 4/29/12 dahondaboy
manx cafe exhaust 115.00 sold 4/18/12 Ccrider
battery rubber boot 1.00 sold 4/18/12 Ccrider
neg grnd wire 1.00 sold 4/18/12 Ccrider
new 2-1 throttle cable 15.00 sold 4/18/12 Ccrider
throttle tube asy 2.00 sold 4/18/12 Ccrider
side kickstand w/ hardware 12.00 sold 4/18/12 BobberNick
new a/m horn 3.50 sold 4/18/12 BobberNick
rubber tank mount 1.00 sold 4/18/12 BobberNick
rear brake reservoir bracket 1.00 sold 4/18/12 BobberNick
starter switch asy 0.00 sold 4/18/12 BobberNick
rear brake pedal pivot 6.00 sold 4/17/12 thelowlife
pivot lost in int'l customs Refunded 18.95 CAD 5/18/12 thelowlife
top motor mount 15.00 sold 4/15/12 gotmark73
new clutch cable 5.00 sold 4/13/12 Furious D
new a/m blinker set 5.00 sold 4/13/12 Furious D
2" chrm tach & speedo gauge set 35.00 sold 4/13/12 Furious D
rear axle 0.00 sold 4/13/12 Furious D
new a/m chrm mirrors 15.00 sold 4/12/12 Coleman67
battery strap 2.00 sold 4/12/12 Coleman67
speedo drive 5.00 sold 4/12/12 Coleman67
sprocket lock tab 3/pk 2.00 sold 4/11/12 Tim of DO THE TON
new throttle cable 5.00 sold 4/11/12 Fleksta
used oem L intake manifold 3.00 sold 4/11/12 Fleksta
used oem R intake manifold 3.00 sold 4/11/12 Fleksta
a/m headlamp brackets 25.00 sold 4/11/12 Captmilk
Will those blinkers fit right in the standard holes for an 80 650?
Sorry, I'm new, but I'd like to pull out the beefy old ones and just "plug and play" new ones, is this possible?
Oh, also, same question about the tach and speedo, if I could just pull out my old OEM ones and pop yours in? Thanks!
QUOTED TEXT: "Will those blinkers fit right in the standard holes for an 80 650? Sorry, I'm new, but I'd like to pull out the beefy old ones and just "plug and play" new ones, is this possible?" -OctoberNotice
Hi, I am new here as well. Long time reader, first time poster. I would test fit the blinkers on my bike however I no longer have the stock fender or headlamp brackets like yours. They will mount the same as oem via a threaded stud and nut backing. The threaded stud is approx 3/4" long and 5/16" diameter. I pulled them from the package for a couple additional photos of said dimensions.
The tach and speedo will mount in the same position as stock but you will ditch the original bracket and use the supplied bar mounted brackets. They have a pos(+) and neg(-) wire for illumination. Both are connected to their respective mechanical drive cables. Full item description from original purchased: http://www.jcwhitney.com/chrome-speedometer-2-1/4/p2008923.jcwx?filterid=u0j1 and http://www.jcwhitney.com/chrome-tachometer2-1/4/p2008924.jcwx?filterid=j1
I'll take the turn signals if they are still available, Clutch cable and rear axle also.
what ratio is the speedo?
My receipt for the speedometer doesn't note the ratio nor does the item description on their website. http://www.jcwhitney.com/chrome-speedometer-2-1/4/p2008923.jcwx
The face of it reads 60MPH=2240RPM if that helps.
Clutch cable and rear axle is yours. We'll give OctoberNotice until tomorrow to reply/confirm on the turn signals and gauges.
